[MO] NEW AFR 1095 comp heads, Complete t56 swap,383 shotblock with xfi cam
Old Jan 24, 2011 | 01:37 PM
5.0 Eater's Avatar
Car: 1989 IROC-Z
Engine: 383 waiting on afr 195 comps
Axle/Gears: 3.42 Posi
I unfortunely have to sell my go fast parts and de-mod my iroc and sell it.
First off is my new, unused, perfect afr 1095 eliminator heads. I bought these from black88z-71 and never installed them because i ran out of cash for the other parts i needed. These heads are fully cnc'd and i got them with the 8002 spring option which is 1.55" od springs 170# @1.980 and 430# @ 1.430 with max lift at .650. I also got upgraded 7/16 arp rocker studs. These are perfect for mild to wild h/r cams and even a few mild s/r cams. These heads are the best "street/strip" heads on the market. Afr sells them for about 2100 shipped with my options and I'll let them go for $1,700 obo shipped with a $100 set of felpro head,intake, and exaust gaskets. Dont miss out on these.
Second is my complete t56 swap. Every part needed to swap a t56 in your thirdgen
complete trans
lt1 fltwheel
lt1 starter
lt1 used HD clutch and pressure plate
lt1 pedals and hydraulics
swap crossmember
b&m ripper shifter
cable driven speedo tail housing
manual shifter boot and plate
All this for $1,000 firm plus shipping if nessessary.
Last is my 383 shortblock. It is a 99 vortec 5.7 engine. It has std bore hyper pistons, stock rods, and an eagle int bal cast stroker crank. Good oil pressure and does not smoke at all. It also comes with a comp XFI 280 H/r cam. asking $600
Here's a couple pics of the heads. More at request. Thanks
Attached Thumbnails NEW AFR 1095 comp heads, Complete t56 swap,383 shotblock with xfi cam-iphone-pics-035.jpg   NEW AFR 1095 comp heads, Complete t56 swap,383 shotblock with xfi cam-iphone-pics-036.jpg   NEW AFR 1095 comp heads, Complete t56 swap,383 shotblock with xfi cam-iphone-pics-037.jpg
Old Jan 24, 2011 | 03:14 PM
Steve Mack's Avatar
Car: 87 Iroc
Engine: modified 350
Transmission: high performance built 700R4
Axle/Gears: Strange S60 3:73
Re: NEW AFR 1095 comp heads, Complete t56 swap,383 shotblock with xfi cam
Do you have any pics of the short block?Thanks,Steve
Old Jan 24, 2011 | 04:18 PM
5.0 Eater's Avatar
Car: 1989 IROC-Z
The motor is sitting in the car Steve and there isnt much to see but i can snap a couple pics if you want. what do you want to see? The cylinder bores look good. Its the vortec so it uses the plastic timing cover.
Old Jan 24, 2011 | 05:46 PM
Steve Mack's Avatar
Car: 87 Iroc
Do the cylinders have a ridge on top or rust.Are the piston tops caked with oil?how many miles on the block?Thanks,Steve
Old Jan 24, 2011 | 06:05 PM
5.0 Eater's Avatar
Car: 1989 IROC-Z
I see, The motor has about 12000 miles on it, no rust, no carbon, ill get you some pics tomorrow.
Old Jan 24, 2011 | 06:18 PM
Steve Mack's Avatar
Car: 87 Iroc
Thanks,any idea on the cost to ship to Connectcut 06076?did you have the block built yourself?Was the rotating assembly balanced?
Old Jan 24, 2011 | 09:24 PM
5.0 Eater's Avatar
Car: 1989 IROC-Z
No idea on shipping, that will be the tuff part. I had the machine work done professionally and I assembled it. The rotating assembly was balanced internally. This is a tuff motor and it has made over 400 rwhp with my etec 200s and a hsr intake. The only reason I'm selling it so cheap is because I need to move this stuff quick.
Old Jan 25, 2011 | 08:18 AM
Steve Mack's Avatar
Car: 87 Iroc
Hi 5.0 any pics of the block or paper work? I can put out a feeler for U-ship on the internet for shipping costs just need your zip.Thanks.Steve
Old Jan 26, 2011 | 12:21 PM
5.0 Eater's Avatar
Car: 1989 IROC-Z
Sorry its taken so long. Here are a couple basic pics. There is a little serface rust but its no big deal. My zip is 65781. Thanks
Attached Thumbnails NEW AFR 1095 comp heads, Complete t56 swap,383 shotblock with xfi cam-iphone-089.jpg   NEW AFR 1095 comp heads, Complete t56 swap,383 shotblock with xfi cam-iphone-090.jpg   NEW AFR 1095 comp heads, Complete t56 swap,383 shotblock with xfi cam-iphone-091.jpg
Old Jan 26, 2011 | 12:22 PM
5.0 Eater's Avatar
Car: 1989 IROC-Z
one more
Attached Thumbnails NEW AFR 1095 comp heads, Complete t56 swap,383 shotblock with xfi cam-iphone-092.jpg
Old Jan 26, 2011 | 01:31 PM
87350IROC's Avatar
Car: 87' IROC
Hey, I'm interested in the T-56.
How many miles?
What year car is it from?
Do you have pics?
Can you also take a pic of the part number?
Thanks.
Old Jan 26, 2011 | 07:01 PM
5.0 Eater's Avatar
Car: 1989 IROC-Z
No pics of the tranny because it is sitting in the car. Miles are somewhere around 100,000 came out of a 96ss car.
Old Jan 26, 2011 | 07:23 PM
87350IROC's Avatar
Car: 87' IROC
Ok, I am interested. Are there any pictures or can you get me the numbers cast into the case. I think they should be easily visible from under the car. I just want to confirm the gear ratios.
Also, I would probably have it sent to Tick performance for a rebuild. So could you give me a total for the trans sent to zip 28115 and everything else sent to zip 98203?
Thanks, if we can get this worked out in the next few hours. I'll have payment to you tonight.
Old Jan 27, 2011 | 11:47 AM
5.0 Eater's Avatar
Car: 1989 IROC-Z
You have a pm
Old Jan 30, 2011 | 10:15 AM
5.0 Eater's Avatar
Car: 1989 IROC-Z
bump
Old Feb 1, 2011 | 01:33 PM
1985.camaro.350's Avatar
Is the t56 swap still for sale? If so how much shipped to 03053?
Old Feb 1, 2011 | 02:06 PM
1986chevycamaro's Avatar
Car: 92camaro,86 camaro
Engine: 355
whats the compression on the 383?
Old Feb 8, 2011 | 09:46 PM
5.0 Eater's Avatar
Car: 1989 IROC-Z
Hey guys, sorry it's been a while. I'm back in the game and I'm ready to get to work on removing the engine and trans and get them sold. I really need to move these heads because every time I look at them they start calling out to me saying summer is just around the corner, USE ME! Needless to say I am more motivated to get them out of my sight. Make a reasonable offer and I just might accept it.
Anyone wanting the motor or trans I'm willing to ship it but I could use a little advise on who to use.
Old Feb 8, 2011 | 09:47 PM
5.0 Eater's Avatar
Car: 1989 IROC-Z
flatt tops with valve releifs so around 10-10.25 I think. let me kmow if you need anything else
Old Feb 8, 2011 | 09:52 PM
Engine: 355
I have to pass. Looking for lower compression thanks
Old Feb 11, 2011 | 01:17 PM
5.0 Eater's Avatar
Car: 1989 IROC-Z
ttt
Old Feb 11, 2011 | 02:32 PM
watajob's Avatar
Car: 92 T/A 'vert
Engine: Mild .040 over L98 4 bolt mains
Transmission: Mostly stock 700R4, 2600 Vigilante
Axle/Gears: LS1 3.42
PM sent.
Old Feb 12, 2011 | 11:14 PM
5.0 Eater's Avatar
Car: 1989 IROC-Z
replied
Old Feb 13, 2011 | 08:08 PM
jak1997's Avatar
Want a title? Post!
Car: 1984 Z28
Engine: 383 Stroker
Axle/Gears: 3.73 Posi
Is theT56 still available if so estimate shipped to 44095
Old Feb 13, 2011 | 08:20 PM
watajob's Avatar
Car: 92 T/A 'vert
Originally Posted by 5.0 Eater
replied
Never got it. Please try again.
Old Feb 13, 2011 | 09:23 PM
5.0 Eater's Avatar
Car: 1989 IROC-Z
sale pending on motor and trans
Old Feb 20, 2011 | 04:32 PM
5.0 Eater's Avatar
Car: 1989 IROC-Z
ttt
Old Mar 24, 2011 | 07:43 AM
2600-watt-rs's Avatar
Car: 1991 Camaro RS
Engine: Transplant 350, Building 355
Axle/Gears: Stock
T56 swap still available?
Old Mar 24, 2011 | 04:48 PM
CamKid1992's Avatar
Car: 1992 Camaro
Engine: HSR 355, afr 195s, xfi280, Holley e
Transmission: t-5
Axle/Gears: Braced 10 bolt Auburn and 3.73s
interested in t56 swap if you still have it. im right down the highway from you
Old Mar 25, 2011 | 11:47 PM
stingrayguy's Avatar
pm sent on heads
Old Mar 30, 2011 | 03:56 PM
5.0 Eater's Avatar
Car: 1989 IROC-Z
Motor and trans are sold. Sale pending on heads. Thanks
Terrell351
Jun 13, 2021 01:13 PM
Reddeath210
Oct 6, 2015 08:20 AM
355tpipickup
Aug 13, 2015 07:35 AM
89mulletbird
Aug 12, 2015 07:08 PM
89mulletbird
Southern California Area
Aug 10, 2015 10:16 AM
