LT1 Cam
Old Jan 26, 2011 | 10:47 PM
bduffey723's Avatar
Car: not a camaro anymore
LT1 Cam
i bought it not too long ago and im never going to use it. it is a great upgrade for a 305 if u havent heard. it is used so no reasonable offer will be turned down.
specs
- mileage 89k
- 94 caprice
cam specs
- 201/208° @ .050"
- .447"/.459" with 1.5 rockers
- 117° LSA
price
- $40+shipping?
Old Jan 29, 2011 | 01:51 PM
bduffey723's Avatar
Re: LT1 Cam
ttt
Old Jan 30, 2011 | 11:14 PM
bduffey723's Avatar
Re: LT1 Cam
ttt
Old Jan 31, 2011 | 01:01 AM
giszo's Avatar
Car: 1992 Camaro RS
Engine: 3.1L V6
Transmission: 700-R4
Re: LT1 Cam
Maybe some technical information on the camshaft, the mileage and a price would help you to sell this.
Old Jan 31, 2011 | 02:38 AM
F-Body Demon's Avatar
Re: LT1 Cam
I know its a PITA but do you have the specs on the cam?
Old Jan 31, 2011 | 11:52 AM
bduffey723's Avatar
Re: LT1 Cam
specs
- mileage 89k
- 94 caprice
cam specs
- 201/208° @ .050"
- 117° LSA
price
- $40+shipping?
Old Feb 2, 2011 | 12:03 AM
bduffey723's Avatar
Re: LT1 Cam
tothetop
Old Feb 2, 2011 | 09:16 PM
Werewolf SS's Avatar
Car: 1989 Camaro RS
Engine: V6 - LS Swap Incoming
Transmission: 700R4 - T56 Mag F Incoming
Re: LT1 Cam
Would you take 30 shipped to Fl.?
Old Feb 3, 2011 | 06:45 PM
bduffey723's Avatar
Re: LT1 Cam
bump
Old Feb 3, 2011 | 07:01 PM
Chevy86 IROC-Z's Avatar
Car: 1986 Camaro Z28 IROC-Z
Engine: 350 Tuned Port Injection, for now.
Axle/Gears: Posi - 3.23
Re: LT1 Cam
does it have the short or long dowel pin? what is the castin number that is stamped on the end? should say something like "BC******."
Old Feb 3, 2011 | 07:37 PM
bduffey723's Avatar
Re: LT1 Cam
it has the long one. ill go check the number..
number is BC-15---242-GMPT-
Old Feb 4, 2011 | 01:42 PM
bduffey723's Avatar
Re: LT1 Cam
Old Feb 4, 2011 | 06:19 PM
92droptopws6's Avatar
Car: '88 Trans Am
Engine: 5.7L TPI
Transmission: Slushbox
Re: LT1 Cam
Pm sent to wolf
Old Feb 5, 2011 | 02:00 PM
bduffey723's Avatar
Re: LT1 Cam
ttt
Old Feb 7, 2011 | 12:57 PM
bduffey723's Avatar
Re: LT1 Cam
happy monday everyone
Old Feb 10, 2011 | 01:42 PM
bduffey723's Avatar
Re: LT1 Cam
ttt
Old Feb 11, 2011 | 12:12 PM
FlippindaBird's Avatar
Car: 1987 Firebird, Dad bought it new
Engine: 5.7L Vortec w/ LT4 Hot cam
Transmission: 700r4 transgo shiftkit 2600 stall
Axle/Gears: 3.42 '02 SS 6 spd rear
Re: LT1 Cam
pardon my pessimism but i always thought only Fbodies came with that grind and the Bbody cam was somewhat smaller, say 430/440ish... correct me if im wrong, just curious
Old Feb 11, 2011 | 01:14 PM
Re: LT1 Cam
From 85 to 86, the grind got smaller which lowered HP but torque increased. The LT1 has a higher lift than the 87 and up 350 IROC's. The LT1 has even a much higher lift than the 87 350 and up. The lift is still within specs of the ECM which vacuum is not affected.
Old Feb 11, 2011 | 03:26 PM
Re: LT1 Cam
i assume you mean 95/96? 93 the specs were 450/460 with the short dowel... all after that were 447/459 with the long dowel, duration was the same but this was the Fbody cam... the Bbody cam was smaller, still larger then an L98 cam but with the L98 cam at 401/415 lift thats not that hard... of course the duration is short because of the FI... my point was that the Bbody cam is smaller then the OP's claim of 447/459, but again i COULD be wrong, i just doubt it
Old Feb 11, 2011 | 03:34 PM
Re: LT1 Cam
1985 IROC had a larger cam than the 1986 cam. I think the OEM 86 cam was called the "peanut cam". The loing dowel pin can easily grinded down. The MAJOR difference between the L98 is that the L98 of course has a small lift than the LT1, but the L98 has a front lobe for a engine mounted fuel pump while the L98 has no front lobe.
Old Feb 11, 2011 | 03:38 PM
Re: LT1 Cam
85 iroc had the L98 cam in a 5.0L... but again what im saying is a "Bbody" has a smaller cam then an "Fbody" with an LT1 nothing to do with the TPI engines... his cam came from a 94 caprice
Old Feb 11, 2011 | 04:07 PM
Re: LT1 Cam
Is it the L98 cam. I knew it was bigger than the 86 305.
Old Feb 11, 2011 | 04:13 PM
Re: LT1 Cam
yes same specs, its on here somehwere, i remember when it came out lol the 85 WAS the fastest 5.0L until they put the dual cats on and put the 5sp behind it in 91 i owned an 85 iroc and a 91 Z28 5p the 5sp was way more fun lol
Old Feb 11, 2011 | 04:24 PM
Re: LT1 Cam
Yup. i mean you got the L98 and the 5 spd which has no los because there is no torque converter. funny how you can have the same exact engine but having a auto or manual would make the differnce in HP.
Old Feb 11, 2011 | 04:33 PM
Re: LT1 Cam
yes... too bad they never made a L98 5sp
Old Feb 11, 2011 | 04:58 PM
Re: LT1 Cam
No kidding. Imagine the jump in HP with that L98 and 5 spd.
Old Feb 11, 2011 | 05:39 PM
bduffey723's Avatar
Re: LT1 Cam
sorry guys if i do have the wrong specs. but that is the part number off the cam so that shuould give the right info. i bought the cam about 6 months ago and thats what i bought it off of. im probably wrong tho LOL ill search the PN and see what happens.
Old Feb 13, 2011 | 10:33 PM
bduffey723's Avatar
Re: LT1 Cam
searched PN and only results i get are ppl on other websites asking the same question... if anyone else has any info please share
Old Feb 15, 2011 | 11:45 AM
bduffey723's Avatar
Re: LT1 Cam
bump
Old Feb 23, 2011 | 03:38 PM
larry88ttops's Avatar
Car: 1988 Camaro w/T Tops
Engine: 305 TBI
Transmission: Borg-Warner 5 spd
Re: LT1 Cam
Do you still have this? I show that the spec's you illustrated are for the LT1 cam that was in the 95-97 Vette. At least that's what my GM parts guy says.
Old Feb 23, 2011 | 03:53 PM
bduffey723's Avatar
Re: LT1 Cam
ya thats what the debate was above.. here is the part number if u can get specs from it.. i couldnt find any.
GMPT-BC-15---242
Old Feb 23, 2011 | 04:04 PM
Engine: 305 TBI
Re: LT1 Cam
OK - my parts guy will be back in tomorrow morning. I will quiz him to see if he can cross reference the stamping to a part number and/or spec. Thanks.
Jorlain
Oct 8, 2015 01:57 AM
New2Chevy
Sep 28, 2015 12:35 AM
88 TA GTA
LSX and LTX Parts
Sep 11, 2015 11:31 PM
L0tuS
Sep 4, 2015 11:16 PM
Strick1
Sep 4, 2015 07:11 AM
15, 242, bc, cam, gm, gmpt, lt, lt1, mpt
