[NY] World Class T-5 Swap, 350 roller engine, aluminum shaft and more!!!
Car: 2000 SS 1991 Z28 VERTS
Engine: LS1 TPI
Transmission: T56 TKO500
Axle/Gears: 4.10 3.73
All items I have for sale came out of a 1989 Trans am and are in perfect working order unless otherwise noted, my friend upgraded to a LT4 Vette and no longer needed these parts, so I purchased them from him to build myself another third gen, but lost interets and want these items gone. All reasonable offers will be entertained:
1) World class T-5 swap for a third gen. Comes with pedals, tranny, bell housing, fly wheel, short throw pro 5.0 shifter, clutch master and slave cylinder, billet front bearing retainer, not installed though. No clutch or presure plate, I think the speedo sender is bad, cause the speedometer would not work. Asking $400 OBO
SOLD
2) Aluminum drive shaft Asking $100.00 OBO SOLD
3) Just broken in 350 small block (short block) with TRW Speedpro .125 domed hypereutectic pistons floating pins, speed pro file fit moly rings ballanced and shave rods, HV oil pump, new bearings throughout, dual roller timing chain, stock oilpan, edelbrock aluminum timing cover, add your heads and upper end plus cam and go! This engine ran low 12's with a stealth ram setup on street tires. Asking a very fair $500.00 OBO
4) Dual fans w/o upper or lower mounting brackets Asking $75 OBO SOLD
For immediate response call me directly @ 518-610-1773. If I don't answer leave a message, because the cell coverage where I live is terrible. I will call you back promptly. The items are for pick up only I am located in Saratoga Springs, NY. I rarely check PM's, so if you are really interested please call.
SOLD
Car: 1987 Firebird, Dad bought it new
Engine: 5.7L Vortec w/ LT4 Hot cam
Transmission: 700r4 transgo shiftkit 2600 stall
Axle/Gears: 3.42 '02 SS 6 spd rear
Re: World Class T-5 Swap, 350 roller engine, aluminum shaft and more!!!
if i had the cash right now id get the tranny... how many piece rear main seal is the engine? what cam is in it?
Engine: LS1 TPI
One piece rear main. As stated all items came out of an 89 trans am.
Engine: LS1 TPI
I suppose, but all actual shipping costs will be incurred by the buyer. I could drop it at a frieght hub if it's somewhat close. I really don't want to have to go through that. I'm sure shipping is going to be expensive.
Engine: LS1 TPI
All PM's replied. I have a potential buyer coming up to look at it on Saturday. FYI...
Engine: LS1 TPI
bump
Engine: LS1 TPI
bump
