Complete turbo kit for 3rd gen $1000 FIRM
Old 05-10-2011, 04:45 PM
f355bird's Avatar
Car: 1985 Iroc-Z
Transmission: t-5
NEW ROCK BOTTOM PRICE 1,000 FIRM PLUS SHIPPING!!!
I have a project that ive decided i dont want to build anymore so now its time to unload my collection of parts.
Complete 70mm garrett turbo kit custom made
Garrett, AR/70 Turbo in excellent condition no shaft play at all, 70mm inducer, 1.00 exhaust wheel stainless compressor housing T4 flange
70mm waste gate set at 15 psi, have hardware to set at 10 psi
38mm Blow off Valve
Home made Headers and tubing made from flow-tech headers.
3.5 inch downpipe with air fuel sensor, mandrel bends
Aluminum carb hat
Pneumatic carb spacer
Intake tubing is Injen and Specter brand
Blow thru prepped Holley carb (model 1850)
100 gph NASCAR mechanical boost referenced pump
Stainless steel braided fuel lines
Tapped oil pan for return line
Liquid filled fuel pressure gauge, 0-40 psi
Mechanical boost gauge
Air fuel gauge Auto meter cobalt series
Electronic boost gauge auto meter cobalt series
Heat wrap
Set up comes with all oil lines and everything to hook up with the exception of a new air cleaner for the turbo.
System was on a third gen 1984 camaro with a stock 305 motor With 9 to 1 comp. The car made 400 hp with a virtually stock motor with an aluminum intake and hei distributor, and with 15 psi boost. With a built motor with forged pistons it could easily make over 600 hp.
here is a video of the kit in action
http://www.youtube.com/watch?v=engdV2rDX8o
Attached Thumbnails Complete turbo kit for 3rd gen 00 FIRM-hpim1372.jpg   Complete turbo kit for 3rd gen 00 FIRM-kgrhqqokiqe1-ri-wt0bnc7-6leog
Old 05-20-2011, 12:37 PM
BronYrAur's Avatar
Car: 91 Camaro RS Convertible
Engine: 305 TBI
Transmission: 5-Speed
Re: Complete turbo kit for 3rd gen $1500 obo
PM'd you
Old 06-14-2011, 05:27 PM
f355bird's Avatar
Car: 1985 Iroc-Z
Transmission: t-5
ttt ive been really busy back up for sale make me a reasonable offer everything is boxed and ready to ship.
Old 06-15-2011, 04:01 PM
kenlamb3's Avatar
Car: 91 Z28 Convertible Camaro
Axle/Gears: Borg-warner 3:27 gears
Do you know if this will work on the Tpi 305?
Old 06-15-2011, 05:19 PM
f355bird's Avatar
Car: 1985 Iroc-Z
Transmission: t-5
it will work but u would have to change the intake piping to go to the tpi instead of the carb. Other then that is the same.
Old 06-15-2011, 07:34 PM
BronYrAur's Avatar
Engine: 305 TBI
Will it clear a stock Camaro hood? Looks like it'd be close with the turbo in front of the radiator there. I'm trying to visualize the setup, would it clear an A/C compressor or no? I assume you had a V-belt setup on an 84, this would be on a serpentine setup, I'm interested, just making sure it's worth my while because I don't have the means to fabricate much in my current location.
Old 06-15-2011, 07:43 PM
f355bird's Avatar
Car: 1985 Iroc-Z
Transmission: t-5
It would require a cowl hood or a hole in the hood to clear. The a/c I will have to take a look and see. As far as serpentine setup I don't think that would be a problem.
Old 06-26-2011, 01:49 PM
f355bird's Avatar
Car: 1985 Iroc-Z
Transmission: t-5
TTT new price
Old 07-05-2011, 12:54 PM
f355bird's Avatar
Car: 1985 Iroc-Z
Transmission: t-5
Re: Complete turbo kit for 3rd gen $1000 FIRM
ttt
Old 07-07-2011, 04:17 PM
KnightmareCS's Avatar
Car: 82,83,99 T/As
Engine: 350,350,383
Transmission: ST-10,700r4,4l60e
Axle/Gears: P-3.23,P-3.42?,P-4.10
Nice deal.
Damn, if it only didn't require a bigger hood...
Free bump.
Old 08-11-2011, 07:42 PM
5.0slayer's Avatar
Car: 91 camaro RS
Engine: 350, forged 355 in the works
Transmission: 4 speed goin to th400
Axle/Gears: stock 9bolt, 3.27
Still for sale
Old 08-11-2011, 07:56 PM
f355bird's Avatar
Car: 1985 Iroc-Z
Transmission: t-5
Yes still have a lot of people have been interested but no one has showed money yet
Old 08-11-2011, 08:06 PM
5.0slayer's Avatar
Car: 91 camaro RS
Shipping to 44130
Old 08-11-2011, 08:13 PM
f355bird's Avatar
Car: 1985 Iroc-Z
Transmission: t-5
100 for shipping should be fine
Old 08-12-2011, 07:29 AM
5.0slayer's Avatar
Car: 91 camaro RS
PM'ed
Old 10-02-2011, 07:48 PM
85z28kid's Avatar
Car: 85 iroc-z28
Engine: 049 headed bbc 4?? C.I.D
Axle/Gears: 3:73 posi
Still got turbo setup?
TreDeClaw
Theoretical and Street Racing
06-22-2021 08:21 PM
Terrell351
06-13-2021 01:13 PM
Casey Meyers
03-02-2016 10:46 AM
KO1
08-31-2015 06:31 PM
TreDeClaw
08-14-2015 06:58 PM
Quick Reply: Complete turbo kit for 3rd gen $1000 FIRM
