[Sold] Comp Xfi280 cam
Old Jul 25, 2011 | 11:28 AM
Cody Ashby's Avatar
Car: 1991 Firebird Formula
Engine: 6.0 LQ4
Transmission: TKO600
Comp Xfi280 cam
As title reads, i have a comp cams xfi280 hydraulic roller camshaft forsale with just shy of 1500 miles on it. Cam is in perfect condition, looks like it just got pulled out of the box, lobes are perfect! Im looking to get $185 obo for it. Feel free to text me or call me with any questions and i can send pics through text or email, whatever is easiest. I will be posting pics on here within the next few days when i can get my hands on a digital camera. Number is 563-570-0713. Thanks for looking guys. Specs below.
http://www.compperformancegroupstore...ory_Code=HRXFI
Attached Thumbnails Comp Xfi280 cam-dscn1263-r.jpg   Comp Xfi280 cam-dscn1265-r.jpg   Comp Xfi280 cam-dscn1267-r.jpg
Old Jul 25, 2011 | 10:33 PM
ScottyRock's Avatar
Car: 92 L98 Z28 Heritage Hard Top
Engine: L98 350 w/ HSR,24lbs inj,AFPR
Transmission: TCI Super Street Fighter W/3300 sta
Axle/Gears: 3.73 Detriot NoSpin,LPW cover
Re: Comp Xfi280 cam
What springs would I have to use on a stock iron headed L98?
Old Jul 26, 2011 | 09:35 AM
Cody Ashby's Avatar
Engine: 6.0 LQ4
Re: Comp Xfi280 cam
I believe comp recommended the 26918 behive springs. But I would call comp cams or your preffered spring company and see what they recommend..
http://www.compperformancegroupstore...&Category_Code=
Old Jul 26, 2011 | 03:28 PM
83 Crossfire TA's Avatar
Re: Comp Xfi280 cam
Do you have a part number/application? There is more than one version of that cam. Pics?
I'm curious, why did you end up pulling it?
Old Jul 26, 2011 | 03:32 PM
Re: Comp Xfi280 cam
Actually, I just looked at your link, so it's the HR retrofit version (won't work with a retainer plate/needs cam button/something to push against)?
Old Jul 26, 2011 | 04:04 PM
Re: Comp Xfi280 cam
huh... so actually I'm back to the original question, do you know if it's the 55-85 or 86 and up version? The website lists it as the 55-85 and shows that style cam in the picture, but the PN starting with an 08 should be a roller block (86 and up) version (and I'm going to assume that it's not the late LT1 cam which is the same but with a different length dowel pin)
Old Jul 26, 2011 | 05:08 PM
Cody Ashby's Avatar
Engine: 6.0 LQ4
Re: Comp Xfi280 cam
its the 86 and up version because my block is an 89 4 bolt main. I ended up pulling not just the cam but the heads and all and im going back to carburated because i had so many damn issues with my stock computer! I upgraded to some afrs and i had a custom ground cam made by mike jones. Any other questions feel free to ask! pics up tonight! Thanks guys
Old Jul 26, 2011 | 08:33 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: Comp Xfi280 cam
Pic is noted as being generic.
# 12-467-8 would be the retro fit version
If it was the long pin LT1 version (# 07-467-8 ) you can just trim the pin length to suit a earlier roller setup
Old Jul 26, 2011 | 09:32 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Re: Comp Xfi280 cam
beehives be minimum rating for that cam, but i'd call patriot performance and order their extreme gold kit for sbc/lt1's with 11/32" valve stems. should fit stock spring pockets as its a small diameter spring.
But to be honest, thats way too much cam/lift for stock L98 heads. You'd have to have the heads worked over to handle the lift and even then i think its too high lift for the flow profile of the stock L98s.
Old Jul 27, 2011 | 09:33 AM
Cody Ashby's Avatar
Engine: 6.0 LQ4
Re: Comp Xfi280 cam
orr89rocZ has a point, this is a pretty aggressive cam!
Old Jul 27, 2011 | 09:34 AM
Cody Ashby's Avatar
Engine: 6.0 LQ4
Re: Comp Xfi280 cam
for heads like those, probaly better off upgrading heads or the heads would be a weak point..
Old Jul 27, 2011 | 02:48 PM
Cody Ashby's Avatar
Engine: 6.0 LQ4
Re: Comp Xfi280 cam
pics posted fellas
Old Jul 27, 2011 | 05:31 PM
QUICK305's Avatar
Re: Comp Xfi280 cam
If the cam is in as described condition, I would be interested at $175 shipped to 77706
Old Jul 27, 2011 | 05:41 PM
Cody Ashby's Avatar
Engine: 6.0 LQ4
Re: Comp Xfi280 cam
cams perfect man, i just wish i could have found this cam at this price and this condition when i was looking to purchase it. but i had to pay full price..little over 300 with tax. Ill pm you my paypal address
Old Jul 27, 2011 | 05:46 PM
Cody Ashby's Avatar
Engine: 6.0 LQ4
Re: Comp Xfi280 cam
PM sent
Old Jul 29, 2011 | 01:30 PM
Cody Ashby's Avatar
Engine: 6.0 LQ4
Re: Comp Xfi280 cam
Bump..cam still forsale guys, QUICK305 doesnt know how to return PMs after being here for 12 years...
Old Jul 29, 2011 | 08:13 PM
Re: Comp Xfi280 cam
Money sent...
Old Jul 29, 2011 | 11:27 PM
Cody Ashby's Avatar
Engine: 6.0 LQ4
Re: Comp Xfi280 cam
Cam sold to 83crossfireTA!!
F.I. 57 Belair
Aug 23, 2021 01:09 AM
Jorlain
Oct 8, 2015 01:57 AM
customblackbird
Oct 1, 2015 04:30 PM
sandman92084
Sep 12, 2015 10:27 PM
Strick1
Sep 4, 2015 07:11 AM
