Bolt in ford 9 inch
Old Oct 19, 2011 | 03:57 PM
BlueBeast's Avatar
Car: 1985 Camaro
Engine: 565 BBC
Transmission: Glide
Axle/Gears: 9 inch/spool/3.70
Bolt in ford 9 inch
Bolt in 9 inch. 31 spline axles, alumiunm center section, auburn pro posi unit, daytona alumiun pinion support, big ford bearings, 5/8 studs. I also have a 31 spline spool for this if intrested. This is the old south side set up that has the bars welded to the rear that bolt to a crossmember that is welded to the subrames that will come with the rear. This set has been 1.30 60 ft in my car and I have heard of them going hi 7's in the 1/4.
$550.00
Old Oct 19, 2011 | 04:36 PM
91rallyss's Avatar
Car: 91 camaro
Engine: 355
Axle/Gears: 3.42:1
Re: Bolt in ford 9 inch
How wide is this 9inch axle face to axle face? Im interested just kinda wanna no the width first.
Old Oct 19, 2011 | 05:43 PM
LS4GXP's Avatar
Car: 87 Z28
Engine: AFR 383
Axle/Gears: 4:11
Ill take second dibs if he doesnt fall through
Old Oct 19, 2011 | 07:05 PM
BlueBeast's Avatar
Car: 1985 Camaro
Engine: 565 BBC
Transmission: Glide
Its stock length whatever that is. I have run 15x8 with 5.5 back spacing on this rear and they DO NOT stick out. I have also ran 15x10 with 6.5 back spacing with some inner fender mods and they also have not stuck out.
Old Oct 19, 2011 | 07:47 PM
85z28kid's Avatar
Car: 85 iroc-z28
Engine: 049 headed bbc 4?? C.I.D
Axle/Gears: 3:73 posi
I wish you were closer I would take this in a heartbeat.
Old Oct 20, 2011 | 01:53 AM
6SIX6's Avatar
Car: 89 IROC
Engine: LSX 6.0 370, TU2 Cam, Fast intake
Transmission: T56 w/ lots of goodies
Axle/Gears: 8.8, Posi, 4.10, 31 Spline
Free bump . Man that is one bad *** rear end
Old Oct 20, 2011 | 08:07 AM
LS4GXP's Avatar
Car: 87 Z28
Engine: AFR 383
Axle/Gears: 4:11
Still up for grabs?
Old Oct 20, 2011 | 08:07 PM
N.J.-SLICK-1's Avatar
Car: 92 camaro R.S.
Engine: 406 Carbed
Transmission: T-400
Axle/Gears: 3.73 limited slip
$550.00
Wow! Is this still available?
Old Oct 20, 2011 | 08:14 PM
Tony V's Avatar
Car: 88 Camaro
Engine: 383
Axle/Gears: Moser 9 inch/4.11 TruTrac
What gears you got in there?
Old Nov 1, 2011 | 10:31 AM
itsjustabird's Avatar
Car: 91 firebird
Engine: sb2.2 headed sbnos
Transmission: tsi glide
Axle/Gears: 4.30
check your pms! if its still available consider it sold!!!!
Old Nov 8, 2011 | 07:08 PM
BlueBeast's Avatar
Car: 1985 Camaro
Engine: 565 BBC
Transmission: Glide
sold
morrow
Jan 13, 2024 12:29 PM
ZMWojnar
Brakes
May 12, 2019 10:43 PM
IROCZDAVE (88-L98)
Nov 19, 2015 07:03 AM
billybob6110
Sep 23, 2015 01:30 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:49 AM
