[FL] 90 Firebird Formula 350 WS6 PART-OUT
Car: 88 Trans Am
Axle/Gears: Posi
1990 firebird formula with a l98 350 TPI that runs but runs rough like its starving for fuel But runs good when given some gas. hard top, power windows, locks. 700r4 automatic transmission. WS6. Red exterior, tan interior(Seats and carpet are garbage).
It has a complete working AC unit with a label saying it was rebuilt and serviced in 07.
Im in melbourne fl, I can cut up sheet metal if anyone really need that.
Some parts that are for sale that i need gone asap:
$200 - WS6 wheels, center caps, with tires with about 65% tread
$150 - 700r4 transmission (i know it drives but i cant verify what condition its in so i priced it as a rebuildable core 177,000 miles)
Sold:
Radiator/Dual fans and mounting brackets
Headlight motors with control module
Front and rear disks and callipers
Power Window switches
Radio plastic bezel
Center console lid
Radio Mounting Brackets
Headlight switch
Sold:
Radio plastic bezel
Center console lid
Headlight switch
Car: 91 Firebird/88 Firebird/91 Formula
Engine: V6 3.1/V8 5.0/V8 5.0
Transmission: 4L60/700R4/4L60
Axle/Gears: 3.23/2.73/2.73
Re: 90 Firebird Formula 350 WS6 PART-OUT
Looking for a dust cover for my 700r4. Would like to see the driver's door lower gfx, front fender gfx on both sides, and airdam to see if they match my 1991 base firebird.
Dust cover on the 700r4 covers the flywheel or flexplate where it engages the starter.
Want a title? Post!
Car: 1992 CamaroZ28
i need a a fan switch/knock sensor connector with some wire for me to splice, an oil pressure sending unit, and an upper fan bracket for dual fans. shipping is to 17603
Car: 88 Trans Am
Axle/Gears: Posi
WS6 wheels are in great shape, aluminum finish is still good. They still have tires mounted (dont have any info on the tires right now) $225 for all 4
i believe all they center caps are there as well but ill have to check
As i said ill make sure to put up all the pictures by tonight.
Car: 89 GTA
Engine: 383
Transmission: 4L80E
Axle/Gears: 12 bolt-3.73
If you have the fiberglass rear wing, then I want it and will come pick it up.
Let me know.
Let me know.
Car: 91' Trans Am 1le
What kind of rear end is in it? I'm trying to find something that'll match my '91s G80
Car: 88 Firebird formula clone
Engine: Yeah its in there
Transmission: Thats in there too
Axle/Gears: Yeah there in the back
ill take the center caps if theyre available
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
how much for the whole tpi setup?
Car: 91 GTA & 92 GTA & 92 GTA
Engine: 305 TPI & 350 TPI & 350 TPI
Axle/Gears: 3.42 & 3.23 & 3.23
I am restoring a yellow 92 GTA and I am looking for the 14 mm bolt and metal clip that holds the alternator wiring. I believe that all 89-92 TPI cars came with these parts. There is no part numbers available for these parts so I am looking for good condition, rust free parts. Below is a picture for the bolt and clip. The clip should be golden in color and not bent.
I am also looking for 1 charcoal canistor hose holder. The part number is: 10105274 and unfortunately it is discontinued. I am looking for one that is in nice shape and not rusty. The holder bolts in just above the passenger side front fender ground effect and guides the hose through the ground effect. This part was on every 1990-92 Firebird's that came with TPI.
Below is a picture:
Let me know if you have anything. Pictures and prices would be nice. I'd be willing to pay more than what they are worth (within reason) for the above parts so its worth your while if the parts are in nice shape.
Out of curiousity, what kind of shape are the positive and negative battery cables in especially the connectors that clamp down on the battery. Pics would be helpful too.
Below is a picture:
Car: 88 Trans Am
Axle/Gears: Posi
the rear end is a 10 bolt, i dont know the gear ratio and i would assume its posi since this is a formula 350, It doesnt have brakes( i took off the disks for myself) but i can throw in a drum brake setup.
Car: 88 Trans Am
Axle/Gears: Posi
the dual fan bracket has been taken, i can get you the oil pressure sending unit. show me a picture of the fan/switch knock sensor and ill remove it for you. $20 for the sending unit and fanswitch/knock sensor
Is there a way you can find out if its a posi for me? I dont really care about gears or brakes cause I'm putting a 3:73 set in and my car is already a rear disc. Its just that my posi chunk is on the way out and I need something to swap into it.
Want a title? Post!
Car: 1992 CamaroZ28
the fan switch connector will be on the passengers side of the block just below spark plugs #6 and #8. I dont need the sensor, just the connector with some extra wire on it for splicing. The connector should be white in color and you can squeeze its sides and it will pop off. When you locate it pm me and i will send payment.
theshackle
Mar 5, 2017 06:37 PM
