[GA] Jet Performance Chip Stage 2 #19214-S TPI
Car: 1992 Camaro z28
Engine: 350 HSR
Axle/Gears: 3.42's
Just installed a Stealth Ram on my camaro, I ordered a PCM4Less chip to go with it. I thought the car had a stock chip in it , and to my surprise I found this chip instead.
Car ran great before doing my swap 2 weeks ago and it ran Very strong. So to my knowledge this chip is in perfect working order.
This is a copy and paste from summit:
These Stage 2 performance chips/modules from JET will improve the performance of your car or truck with very little work. These chips have been programmed to deliver peak power increases under hard throttle conditions, such as towing and wide-open throttle. They offer a full range of DST programming of the air/fuel ratio, ignition advance, and transmission, and are fully track and dyno-tested to ensure the most possible power without affecting day-to-day drivability.
Stage 2 power chips/modules must use the following for proper performance:
* 180 degree thermostat
* 91 octane or greater fuel
* Free-flowing exhaust
They seem to average about $160.00 NEW
I'll start it out at $100.00 Shipped. I'am very open to offers considering I thought it was a worthless stock chip.
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Jet Performance Chip Stage 2 #19214-S TPI
Is it a memcal or just a piggy back board with eprom ?
Engine: 350 HSR
Axle/Gears: 3.42's
Im guess it was a piggy back board, I had to take this one loose from a brown part and plug mine inn to that and then into the board.
Engine: Lb9
Transmission: M20
ok, If it was a memcal I would be interested
Engine: 350 HSR
Axle/Gears: 3.42's
The one I have looks like the one on the left, just so everyone knows what it looks like.
Engine: 350 HSR
Axle/Gears: 3.42's
Also open to trades:
I need a 85-88 throttle cable for TPI
I am also looking for later style tale lights, the non grid style. No cracks in good condition.
Send me any offers or trades.
Engine: Lb9
Transmission: M20
I have a throttle cable that I would trade I'm more interested in the adapter than the chip anyways.
Engine: 350 HSR
Axle/Gears: 3.42's
Ive got someone wanting to trade some tail lights that got to me first. If it falls through Im interested in the cable. Im also interested if your looking to just sell the cable, if so how much?
Engine: Lb9
Transmission: M20
Not sure what it's worth, will be a few days until I'm able to send you a picture. I just had a surgery today and I will be kinda bed bound for a few days.
NBrehm
Aug 25, 2015 11:49 PM
1989formula5.7l
Aug 15, 2015 11:35 AM
Sanjay
Aug 12, 2015 03:41 PM
