[MI] 406 short block
Old Mar 13, 2012 | 06:22 PM
ridingdead1984's Avatar
406 short block
i have a 406 .030 over 400 sbc a stronger 2 bolt main. Keith black 12.9 pistons 6 inch rod and a internal balanced 3.75 stroke crank comes with balancer and timing chain and timing chain cover and also a oil pump
also have a set of world product 215cc aluminum 2.08 1.60 valves 64cc combustion chamber and also have solid roller cam comp cam .630 .630 lift
short block 1500
heads 1000
cam 200
Old Mar 13, 2012 | 06:32 PM
Whoboy580's Avatar
Car: 1986 Camaro
Engine: 383 Stroker
Transmission: Powerglide
Axle/Gears: 4.10
Re: 406 short block
where you located?
Old Mar 13, 2012 | 06:36 PM
Re: 406 short block
south of detroit
Old Mar 15, 2012 | 04:58 AM
Re: 406 short block
this is assembled with plasma moly rings and new bearings
Old Mar 17, 2012 | 08:02 AM
Re: 406 short block
bump
Old Mar 18, 2012 | 08:16 PM
Re: 406 short block
i can make a package deal
Old Mar 26, 2012 | 07:04 PM
Re: 406 short block
bump
Old Mar 30, 2012 | 09:58 PM
plemon90ta's Avatar
Car: 1990 TA
Engine: 350 in the works
Transmission: th700r
Axle/Gears: 10 bolt Eaton Posi 373
Re: 406 short block
Originally Posted by ridingdead1984
bump
Whats the package deal ? PM me if you dont want to post it. Thanks, Patrick.
Old Apr 3, 2012 | 06:59 PM
Re: 406 short block
pm sent
package deal is with solid roller cam .630 lift
Old Apr 12, 2012 | 04:48 PM
Re: 406 short block
Heads are sold short block with cam and lifters 1900
Old Apr 23, 2012 | 07:08 PM
Re: 406 short block
bump
Old May 6, 2012 | 02:59 PM
Re: 406 short block
anyone interested?
Old May 6, 2012 | 03:39 PM
nothingbutagthn's Avatar
Car: 1989 Pontiac Trans Am GTA
Engine: 2001 ls1
Transmission: built 4l60e with stall
Axle/Gears: 4:10
Re: 406 short block
what city are you in
Old May 7, 2012 | 08:16 PM
Re: 406 short block
just south of Detroit
Old Jun 27, 2012 | 09:48 AM
Rocket-Doc's Avatar
Car: 1990 RS/SS modified
Engine: 355ci, 113 heads, LT4 hotcam
Axle/Gears: 3.73 Eaton posi
Re: 406 short block
Main bearings 350 or 400?
wigmobile
Feb 26, 2025 02:56 PM
Loudnproud86
Jul 14, 2016 12:59 AM
RyanJB
Sep 14, 2015 03:39 PM
Kenwood
Sep 11, 2015 12:50 PM
64goatman
Sep 9, 2015 01:09 PM
