Wanted: Solid Roller Cam
Old Apr 26, 2012 | 12:14 PM
C409's Avatar
Car: '87 Vette C4
Engine: 400 + .040 = 409 ci
Transmission: 700R4 built
Axle/Gears: Dana 44 w/3.42's
........ Hey Guys ... I'm looking for a good used small base circle solid roller cam for a retro or OEM roller block that has specs similar to the Comp Cams XR286R or XR292R ..... basically looking for 106-110 LSA ... 250-260 duration at .050 ... .650 or less lift .......... Thanks , Bob ........
Old Apr 26, 2012 | 08:51 PM
85gulstrandTA's Avatar
Car: was 85 TA, 91 TA both sold
Engine: was 406, now 305 tpi
Transmission: 85 had700r4,350..91 had t5
Axle/Gears: 323,373,342
Re: Wanted: Solid Roller Cam
Well I missed it by that much.....
was going to use this in my 406, solid roller with duration of 272 at .050 had lift of around 710 but I had it lowered to 560 or 570, you know so it would be small enough to drive on the street. cheers for ca.
Old Apr 26, 2012 | 09:53 PM
Justin89Formy's Avatar
Car: 89 formula 350
Engine: ls1 magnuson tvs2300 supercharger
Axle/Gears: 4.11 Dana 44!
https://www.thirdgen.org/forums/engi...id-roller.html
Old Apr 27, 2012 | 04:07 PM
evilemokid94's Avatar
Car: 1986 camaro Sports Coupe
Engine: L31 350
Transmission: 89 700R4
Axle/Gears: 3.42 gov lock
I have a stock cam out of my 96 350
Old Apr 27, 2012 | 06:26 PM
C409's Avatar
Car: '87 Vette C4
.................. ................ I'd be more interested in the cam out of that 2.8 S10 motor .................
Old Apr 27, 2012 | 11:41 PM
also have a custom comp billet solid roller cam 60 miles on it cherry
paid 600 sell 300 firm
280/286
250/254
110 lsa
with 1.6 670/660 gross lift before lash. 1.5 easy to do the math
Sounds nasty will still pull 10 in vac at 1000. Good driving manners despite its sound.
FYI...........This is listed on this site too.
Old Apr 27, 2012 | 11:45 PM
[CA] Forged Gen1 rotating assy. (pics)
Here is the ad it is in....cheers
Old May 1, 2012 | 06:48 AM
C409's Avatar
Car: '87 Vette C4
............. Still Looking ..............
Old May 3, 2012 | 10:44 AM
KWIK84's Avatar
Car: 1984 Z28
Engine: Alky 360
Transmission: TH400, Freakshow 9.5"
Axle/Gears: 9" 4.71
https://www.thirdgen.org/forums/engi...-12-433-a.html
Old May 3, 2012 | 02:38 PM
TB2's Avatar
TB2
Car: 84 Transm
Engine: 350 sbc
Transmission: t400
Axle/Gears: ford 9", 3.90
I have a Lunati 60132 Solid Roller. Worked great! Used one season, but in new condition. $200
http://www.summitracing.com/parts/LUN-60132/
Old May 17, 2012 | 07:59 PM
fastbbt's Avatar
Want a title? Post!
Engine: 427 sbc
Transmission: t400
Axle/Gears: moser 12 bolt
pm sent
Old May 19, 2012 | 03:17 PM
C409's Avatar
Car: '87 Vette C4
........... Still looking ...........
Old May 19, 2012 | 03:47 PM
87zjeff's Avatar
Axle/Gears: '01 3.42 10 bolt
might try posting in the "wanted to buy" section.
Old May 19, 2012 | 08:07 PM
watajob's Avatar
Car: 92 T/A 'vert
Engine: Mild .040 over L98 4 bolt mains
Transmission: Mostly stock 700R4, 2600 Vigilante
Axle/Gears: LS1 3.42
https://www.thirdgen.org/forums/engi...ension-wanted/
Old May 20, 2012 | 08:28 PM
C409's Avatar
Car: '87 Vette C4
.......... Thanks for the bump ............
Hotrodboba400
Dec 10, 2019 07:07 PM
Jorlain
Oct 8, 2015 01:57 AM
Nick McCardle
Sep 10, 2015 08:36 PM
Stryker412
Sep 7, 2015 09:11 AM
