Parting Out Camaro Tons of Performance Parts
Old May 1, 2012 | 08:01 AM
CamMan83's Avatar
Car: 2001 VW Passat
Engine: 1.8 Turbo
Transmission: Automatic 5 speed with Tiptronic
Axle/Gears: Stock
Here is what I have left from my parting out. Shoot me a PM on anything you may be interested in and I will get back with you as soon as possible. Check out my interior parts as well.
Engine (15,000 miles): Asking $5500 (over $10k in it, I have all receipts)
• Supercharged 360 Small Block Chevy
o K&N Xstream Air Flow Air Filter Assembly
o Holley In-line Blue Electric Fuel Pump with Regulator and Gauge
o Edelbrock 750 CFM Performer Carburetor tuned w/ Jets, Rods, Springs and Stubstack
o B&M 144 Roots Supercharger with 10 psi pulleys
o Ported and polished heads with valve job
o Bronze valve guide inserts
o ARP Head bolts
o Comp Cams Hydraulic NX268H-13 Blower camshaft and lifters
o Comp Cams Raised Guide Plates and ARP Rocker Arm Studs
o Manley Street Master Swirl Polished Intake/Exhaust Valves
o Comp Cams dual spring oversized Valve Springs
o Comp Cams 10 degree racing locks and retainers
o Comp Cams Valve Seals
o Comp Cams Heat Treated Pushrods
o Summit Racing 1.5:1 Full Roller Rocker Arms and Lock Nuts
o Billet Double-Row Roller Timing Chain with Thrust Bearing
o Edelbrock Tubular Exhaust System and 3 inch exhaust into Flowmaster 70 Series Muffler and Welded in Cut-Out w/ Electric Valve
o MSD 6AL Ignition Box
o SBC Distributor with Hypertech 53k Volt Coil, Cap and Rotor
o MSD Extreme HEI Distributor Cap and Rotor
o MSD Distributor Advance Kit
o Crane Cams Adjustable Vacuum Advance Canister
o MSD 8.5mm Spark Plug Wires
o Autolite 2 stage cooler Spark Plugs
o Chevy 350 block bored, champherd, torque plated, align bored and surfaced
o ARP four bolt main bolts
o Chevy 350 Crankshaft Cleaned and Polished
o Chevy 350 Rods polished and ARP Wave-loc bolts
o JE Dished -24cc Forged Blower Pistons
o JE Hellfire Rings, Straight wall pins and Spiro locks
o Clevite 77 Cam, Rod and Main Bearings
o Summit High Volume oil pump with welded on pickup
o Stud kit and ARP Oil Pump Driveshaft
o Moroso 6-qt, baffled oil pan for Third Gen Camaro with one piece Fel-Pro Gasket
o Edelbrock Victor Series Water Pump
o 180 degree Thermostat
o Copper 3-core radiator and Electric cooling fan setup with relays
o Fel-Pro Gaskets throughout the whole motor
o SFI Certified Flexplate and 8 inch Steel Damper
o Whole rotating assembly balanced in and out of the motor
o Chrome Dress Up Kit
o Tuff Stuff Gear Reduction Mini Starter
o Optima Red Top Starting Battery
o B&M SuperCooler Engine Oil Cooler with Electric Fan
Suspension:
• BMR Adjustable Panhard Rod -$100
Chassis:
• Factory Steering Brace "Wonderbar" -$45
Transmission (150 miles on the rebuild: Asking $2000)
• Pro-Built TH700R-4 Transmission - $1,700
• Polyurethane Transmission Mount
• TCI 11" Breakaway Torque Converter - $300
• Summit Steel Transmission Pan
Wheels/Tires (lots of tread: Asking $600)
• 16 x 8 Polished Aluminum IROC Wheels
• Falken 245/45ZR16 Tires
Old May 1, 2012 | 08:18 AM
ademarti's Avatar
Re: Parting Out Camaro Tons of Performance Parts
Please give me prices for these:
1) B&M 144 Roots Supercharger with 10 psi pulleys
2) Energy Suspension Polyurethane Sway Bar Bushing Kit
3) Weld-in Subframe Connectors
Old May 1, 2012 | 09:08 AM
jas2730's Avatar
Car: 89 IROC Z/88 IROC Vert
Engine: 350c.i./305c.i.
Transmission: 700R4/T-56
Axle/Gears: 3.42/4.10
How much for the msd 6AL and 8.5mm wires shipped to 26757?
Old May 1, 2012 | 09:29 AM
89newfun's Avatar
Car: 1989 Camaro
Engine: Sbc 355
Transmission: TH350
Axle/Gears: 3.42 Detroit locker
BMR Adjustable Panhard Rod - pm
Spohn Tubular Rear Lower Control Arms - pm
Edelbrock 3-Point Strut Tower Brace ( not the tpi unit right?)
Old May 1, 2012 | 11:10 AM
white1991rs's Avatar
Car: 1991 Camaro RS/1989 Formula
Engine: 5.0 L03 V8
how much for the 34mm sway bar?
Old May 1, 2012 | 04:09 PM
Method_z28's Avatar
Car: 92 camaro z28
price on the prop valve?
Old May 1, 2012 | 05:29 PM
Stu's '85 IROC's Avatar
Can I see pics and a price for the lowering springs? How many miles are on them and how much does it drop the car? I'd need them shipped to Manchester NY 14504. Thanks!
Old May 3, 2012 | 07:49 PM
88blueiroc's Avatar
Can I see some pics of the wheels? Thanks
Old May 3, 2012 | 09:19 PM
evilemokid94's Avatar
Car: 1986 camaro Sports Coupe
Engine: L31 350
Transmission: 89 700R4
Axle/Gears: 3.42 gov lock
willing to sell the carb and dizzy?
Old May 4, 2012 | 12:30 AM
UnderCover89TBI's Avatar
Engine: gone
Transmission: gone
Axle/Gears: gone
would also like a price on the 3 points strut tower brace. thank you.
Old May 4, 2012 | 07:44 PM
blackjack12982's Avatar
What would a shipped price on the wonderbar and SFC's to 40121 be? Most importantly the wonderbar...
Old May 5, 2012 | 10:27 PM
irocz's Avatar
Car: '87 IROC-Z
Engine: 406 Superram/DFI
Transmission: Auto BTE 3000 conv
where did you get all those parts to rebuild the rearend? I'd be interested if there was any way to ship.
Old May 8, 2012 | 06:50 PM
83C_CamAroZ28's Avatar
Car: 1983 Z-28
Engine: 5.7 L
do u still have the Proportioning Valve?
Old May 9, 2012 | 09:53 AM
ctoledo0834's Avatar
Car: 87 camaro Z28 convertible
Engine: 350 carb
Transmission: th-700r4
Axle/Gears: Posi traction 3.42 gears
How much for the • Eibach Pro-Kit Lowering Springs and Welded in Cut-Out w/ Electric Valve and • BMR Adjustable Panhard Rod
Ship to Miami 33010
Old May 9, 2012 | 09:55 AM
Engine: 350 carb
Ship to Miami 33010
Old May 10, 2012 | 03:56 PM
mygta87's Avatar
Car: 89 CHEVY IROC-Z28
Engine: 355 Built/High Performance
Transmission: 700R4 Swap For T56
Axle/Gears: 3.73 Posi
How much for the oil cooler with fan
Old May 10, 2012 | 07:01 PM
syncom's Avatar
Car: 91 Chevy Camaro
Engine: 5.7L 440hp 450FBT
Transmission: WC T-5
Axle/Gears: 3.73 Rear end
items i am interested in are sbc distributor and all that comes with it. edelbrock water pump and radiator with fan system. shipped to 84528
Old May 11, 2012 | 04:50 PM
DrewsCam's Avatar
Car: 1991 Z28
Engine: 355 TPI
Axle/Gears: 9 bolt disc / 3:27
any pictures of the subframe connectors?
Old May 13, 2012 | 03:41 PM
rummie's Avatar
Car: 84 Z-28 / 98 SIERRA Z71
Transmission: 700R4 / 4L80E
Still have the 3core rad and fan setup? And how much. thanks
Old May 13, 2012 | 04:42 PM
Anybody ever hear anything from the seller?
Old May 13, 2012 | 09:33 PM
psmith757's Avatar
Car: 91 Camaro RS
Engine: 5.7 350 TBI
Transmission: t56
Axle/Gears: 4.10
how much for the subframe connectors and what kind are they?
Old Jun 2, 2012 | 01:31 PM
subroc's Avatar
Car: 1988 IROC-Z camaro
Engine: 355 TPI
Transmission: tko 500
Axle/Gears: Dana 44 3.31 posi pbr brakes
which prop valve is it and do you still have it? Price?
Old Jun 8, 2012 | 11:57 PM
fishyz's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Still have the pro-kit?
InfinityShade
Aug 22, 2015 08:00 PM
86IROC112
Aug 17, 2015 02:00 PM
Fronzizzle
Aug 9, 2015 01:15 PM
1nastygta
Aug 8, 2015 07:38 PM
rh76camaro
Exterior Parts for Sale
Aug 6, 2015 08:57 AM
