[MI] Poly Engine Mounts, Eaton Posi, Moser Axles, 3.73 Gears
Old May 7, 2012 | 07:41 PM
eXesiv|83ta's Avatar
Car: 1983 Pontiac Trans AM
Engine: 355 chevy
Transmission: 700R4 Built
Axle/Gears: Built 10 bolt 3.73 gears
Hey guys,
I have:
NIB Stop Tech #950.62001
SS Brake line kit fronts for 98-02 fbody
($60)
I also have a set of 3.73 GM gears for a 10 bolt($60)
I have a set of aluminum drums as well. make offer.
These parts are in good shape.
Call or txt.
eight 1 oh three zero 4 7 nine two one
Justin
Attached Thumbnails Poly Engine Mounts, Eaton Posi, Moser Axles, 3.73 Gears-imag0340.jpg   Poly Engine Mounts, Eaton Posi, Moser Axles, 3.73 Gears-imag0341.jpg
Old May 8, 2012 | 06:32 AM
Ed1LE's Avatar
Car: 91 Firebird 'vert, 91 Formula
Engine: 5.7, 5.0
Transmission: T56, T5
Axle/Gears: Auburn w/ 3.73's, 3.42
Re: Poly Engine Mounts, Eaton Posi, Moser Axles, 3.73 Gears
That eaton Part # is for an 8.5 rear...I'm assuming that's incorrect? How many miles on parts?
Old May 8, 2012 | 03:00 PM
mcgarnicle's Avatar
Car: 1991 Z28 1LE
I also have a set of tubular lower control arms($50)
Are these the rear control arms? If so can you post pics
Old May 8, 2012 | 05:31 PM
400 hp's Avatar
Car: 86 z28
Engine: 355 113 heads ported HSR hot cam
Transmission: th350
Axle/Gears: 7.5 342
pm sent...
Old May 8, 2012 | 08:00 PM
Engine: 355 chevy
That is incorrect. It is for a 10 bolt.
http://www.summitracing.com/parts/ETN-19599-010/
10K miles if that.
Old May 8, 2012 | 11:26 PM
88 Z-ROC's Avatar
Car: 88 IROC-Z (L98)
Engine: Edel. Lwr, SLP Rnrs, Ported Plenum
Transmission: 700R, 2800 Stall
Axle/Gears: 3:42 Posi.(4th gen.) UMI R/Susp.
Are the gears still available..?
How much shipped to 93534
Old May 9, 2012 | 08:32 PM
Engine: 355 chevy
Can ship via USPS for $15. $75 total.
Engine: 355 chevy
OK.
It looks like the axles and posi are sold.
Old May 11, 2012 | 09:14 AM
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
10K miles if that.
The link in your first post goes to part # ETN-19557-010, which is for an 8.5" 10 bolt (although your text says the correct part number). Not sure why the link is wrong.
-- Joe
Old May 11, 2012 | 05:53 PM
Engine: 355 chevy
-- Joe
Hmm I am not sure either. Thanks.
Edit: Fixed.
Old May 11, 2012 | 05:55 PM
Engine: 355 chevy
edited
Old May 15, 2012 | 03:00 PM
Engine: 355 chevy
LCAs are sold.
Apparently people like to say they want them but then they can't afford them...
They are FOR SALE again.
Old May 16, 2012 | 11:06 AM
BLK MAJK's Avatar
Want a title? Post!
Car: 97 GMC Sonoma
Engine: 383
Axle/Gears: GM 8.5 with 4.10s
any idea on the part number for the poly mounts? Looking for these... http://www.summitracing.com/parts/ENS-3-1116G/
Old May 16, 2012 | 01:28 PM
Engine: 355 chevy
I believe they are these. I will confirm tonight.
http://www.summitracing.com/parts/PT...T|Model|CAMARO
Old May 16, 2012 | 04:51 PM
mcgarnicle's Avatar
Car: 1991 Z28 1LE
I would have bought them...
bought new since no reply...
GLWS
Old May 17, 2012 | 07:43 AM
Engine: 355 chevy
GLWS
This was not directed towards you.
Old May 19, 2012 | 06:41 PM
BLK MAJK's Avatar
Want a title? Post!
Car: 97 GMC Sonoma
Engine: 383
get a chance to check on the mounts?
Old May 19, 2012 | 09:09 PM
Engine: 355 chevy
Yes, sorry.
They are for 98 - 02 LS1 cars. The link is in the original post.
Old May 23, 2012 | 05:54 PM
Engine: 355 chevy
Bump it up!
Old Jun 13, 2012 | 07:48 PM
Engine: 355 chevy
Bump! Still have the drums, the SS kit, the motor mounts, and gears.
Attached Thumbnails Poly Engine Mounts, Eaton Posi, Moser Axles, 3.73 Gears-2051807729830_orig.jpeg   Poly Engine Mounts, Eaton Posi, Moser Axles, 3.73 Gears-4051807729851_orig.jpeg   Poly Engine Mounts, Eaton Posi, Moser Axles, 3.73 Gears-6051807729860_orig.jpeg
Old Jun 18, 2012 | 04:27 PM
Engine: 355 chevy
Mounts are sold.
Old Jul 1, 2012 | 01:22 AM
karistanker's Avatar
Car: 89 Sport Coupe Vert (IROC-Z clone)
Engine: 383 Stroker TPI
Axle/Gears: 2.73 (3.73's awaiting install)
If you can guarantee me the those gears are for a GM 10 bolt, I would like them.plz pm me with a shipping quote for 31905. Prefer a brand and part number. Thanks
Old Jul 17, 2012 | 04:00 PM
Engine: 355 chevy
Gears are sold!
hectre13
Dec 11, 2023 08:14 AM
Reddeath210
Oct 6, 2015 08:20 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
novaderrik
Aug 10, 2015 12:44 PM
Elliswon
Aug 10, 2015 12:33 PM
