FS: Comp Cams 280 XFI Hydraulic Roller Cam
Old Jul 26, 2012 | 07:35 AM
C409's Avatar
Car: '87 Vette C4
Engine: 400 + .040 = 409 ci
Transmission: 700R4 built
Axle/Gears: Dana 44 w/3.42's
..... SOLD ... SOLD ..... For Sale ... one lightly used Comp Cams 07-467-8 ... LT1 280 XFI hydraulic roller camshaft ... the dowel pin has been pushed in for a non-LT app ...it can be pulled back out or replaced if needed for your late LT Opti drive ... I have the spec card but here goes ... duration @ .050 is 230 in / 236 ex ... lift .576 in / 570 ex using 1.6 rockers ... LSA 113 ...advertised power band is 2000-6000 rpm with intake and exhaust upgrades recommended ... this is a perfect Hot Street cam with a muscular idle but very driveable ... if you are running stock heads your valve springs will need to be upgraded to accomodate the increased lift ... will bolt in with most aftermarket heads ... I also have some new in box Comp Magnum pushrods in 7.300 and 7.800 if you need them , sold separately ......... $200 plus shipping for the cam ..........
Old Jul 26, 2012 | 06:20 PM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
Re: FS: Comp Cams 280 XFI Hydraulic Roller Cam
Originally Posted by C409
..... one lightly used Comp Cams 07-467-8 ... 280 XFI hydraulic roller camshaft ...
I am interested, but I need to know what that means.
Old Jul 27, 2012 | 07:26 AM
C409's Avatar
Car: '87 Vette C4
.......... In the car for a year and a half ... approx 5000 miles ....... I bought this cam NIB off another forum member who had it for a couple years and it sat on my shelf for a year or more before it was installed ..........
Old Jul 28, 2012 | 05:21 PM
Camaro71's Avatar
Did(do) you run this cam in a genI block?
Old Jul 28, 2012 | 06:37 PM
C409's Avatar
Car: '87 Vette C4
........... Yessir ... I used a cam retainer plate from an L98 to keep the cam and timing set out of the block and made a nose button out of 1/2" aluminum round bar stock to keep the cam from walking out toward the front cover ... Lingenfelter sells a kit to install a step nose cam in a Gen 1 but I didn't find out about their kit 'til after mine was already in and running ......... BTW ... I wound up going solid roller ... that's why this cam is for sale ...............
Old Jul 29, 2012 | 05:42 AM
Camaro71's Avatar
OK, got me thinking...might be something for my 383 build up. Is the anti-cam-walk included with the cam? How would you describe the operation on your engine? What's your combo? Carb/EFI? Nitrous?
Old Jul 29, 2012 | 07:33 AM
C409's Avatar
Car: '87 Vette C4
......... The cam walk stuff is not included ... I have other projects in the works that it would be used on ......... The combo is .040 over 400 or 409 ci ... The best ETs with this cam were with AFR 195 64cc heads 10:1 compression and a FIRST Fuel Inj aftermarket TPI set-up ... Awesome intake BTW ... and Hooker Super Comp 1 3/4" headers ......... The XFI stands for Extreme Fuel Injection and was designed by Comp for computer controlled cars , EFI , and 1.6 rockers ..... Operation was great ... nice muscle car idle , great low end pull , the power limiter was the long runner intake ... it made good power to 5000 rpm then started to fall off ... I switched to an Accel Pro-ram intake ( single plane Victor E style ) and saw no reduction in ETs but had to raise my shift points which led me to the solid roller cam and stiffer valve springs ..... Keep in mind that bigger motors tend to soften-up a cam and vice-versa ... This cam would be pretty stout in a 350 and hefty in a 383 ... if your combo includes carbs or NOS you might want to look at another cam ...
Old Jul 29, 2012 | 07:47 AM
Camaro71's Avatar
...if your combo includes carbs or NOS you might want to look at another cam ...
Well, not quite...the XFI series are an option for nitrous fed engines because of their duration and wide LSA...
Still concidering the options.
Old Jul 31, 2012 | 06:39 AM
C409's Avatar
Car: '87 Vette C4
Old Aug 3, 2012 | 01:20 PM
C409's Avatar
Car: '87 Vette C4
.............. Still Available ....................
Old Aug 6, 2012 | 07:42 AM
C409's Avatar
Car: '87 Vette C4
......... bump ..............
Old Aug 8, 2012 | 12:14 PM
C409's Avatar
Car: '87 Vette C4
Old Aug 8, 2012 | 10:23 PM
unknown_host's Avatar
Car: 1989 Iroc Z L98
Would you consider trading the cam for a solid billet roller?
Old Aug 9, 2012 | 06:16 AM
C409's Avatar
Car: '87 Vette C4
........... Sorry , but I just switched over to solid roller ... got a brand new XR286 in the car now ..........
Old Aug 11, 2012 | 08:05 AM
C409's Avatar
Car: '87 Vette C4
............. weekend bump .............
Old Aug 11, 2012 | 04:36 PM
t/a-speedfreak's Avatar
How much for the 7.3 pushrods?
Old Aug 11, 2012 | 05:36 PM
C409's Avatar
Car: '87 Vette C4
........ The 7.300" pushrods are new in box Comp Cams Hi-Tech Chromemoly 5/16 " .080 wall part # 7949-16 ... I have almost $150 in these with shipping ... I'll sell them for $100 plus shipping ......... Thanks , Bob ...
Old Aug 11, 2012 | 05:59 PM
sheapesz's Avatar
How much for just the cam? I have a 87 305 TPI and From all my research this is suppose to be agreat upgrade over stock?
Old Aug 11, 2012 | 06:11 PM
C409's Avatar
Car: '87 Vette C4
.......... The cam is $200 plus shipping .............. Thanks , Bob ........
Old Aug 13, 2012 | 12:33 PM
Tibo's Avatar
Car: 1991 Z28 Vert
That cam is too large for a 305 TPI. On a 305 stock tpi that cam would make peak power a few thousand RPM after the TPI's designed for.
Old Aug 17, 2012 | 12:37 PM
C409's Avatar
Car: '87 Vette C4
........... Payday Bump ... ..............
Old Aug 23, 2012 | 09:59 AM
C409's Avatar
Car: '87 Vette C4
Old Aug 23, 2012 | 06:58 PM
Tibo's Avatar
Car: 1991 Z28 Vert
Sending pm/email
Old Aug 23, 2012 | 09:22 PM
brdofpry85ta's Avatar
Car: 1985 Trans Am
Engine: 6.6 at least
Transmission: T-56 (waiting)
Axle/Gears: 9" w/4.56 & spool (4 now)
is this still availible.....if so I might have a buyer for you, and we are local....you wont have to ship
Old Aug 29, 2012 | 10:05 AM
Tibo's Avatar
Car: 1991 Z28 Vert
Sale is pending
Old Aug 30, 2012 | 09:07 PM
salem85's Avatar
Car: gunmetal 88 gta 98 yamaha vmax
Engine: l98
Axle/Gears: bw 9 bolt 327
what kind of intake setyup is that? i like the idea pm me about it
Old Aug 31, 2012 | 06:19 AM
C409's Avatar
Car: '87 Vette C4
..... The base is an Accel Pro Ram single plane EFI manifold ... very similar to Edelbrock's Victor E EFI intake ......... the plenum is factory TPI with the runner ports welded up and a 1" open carb spacer welded to the bottom ..... All the stock stuff bolts right on ... Throttle body , TV and throttle cables , Intake Air Temp sensor , and all the needed vacuum ports ... And , it fits under the hood of a C4 Corvette ....... I could fab up another plenum for $350.00 if you're interested .............
Old Aug 31, 2012 | 12:43 PM
salem85's Avatar
Engine: l98
i thought so ive had the same idea for awhile just havnt got around to doing it except i was goin to use a dual plane carb intake like a weiand stealth how did it run?if i sent u the plenum and spacer plate what would u charge?
Old Aug 31, 2012 | 03:05 PM
C409's Avatar
Car: '87 Vette C4
..... Most dual plane intakes make it difficult to weld in the injector bungs mainly due to the different heights of the runners ... the bungs have to be leveled and in the same plane in order to fit a fuel rail in ......... I used an Edelbrock Torker II single plane and the results were similar to the Accel but with a lower peak power rpm ... 6000 vs 6800 ............ some of that is because of my combo ..... the other difficulty is the thermostat housing ........ that requires welding and tweaking depending on who gets priority to the real estate ... thermo hsg or Throttle body ... both are necessities ......... Runs Awesome ... I'm dealing with starting line issues right now but I've got a torquey motor to begin with .... I'd get you welded and ready to bolt-on for $250 ... plus shipping of course ... the spacer plate HAS to be billet ... the cast junk won't weld properly .......... Thermo housing welded up for $100 .........
Hotrodboba400
Dec 10, 2019 07:07 PM
Jorlain
Oct 8, 2015 01:57 AM
Nick McCardle
Sep 10, 2015 08:36 PM
Strick1
Sep 4, 2015 07:11 AM
