KY - 12 bolt - bolt in for 3rd gen
sold
12 bolt from a 68 chevelle that's been converted to bolt in a 3rd gen. It does have provisions for torque arm mount welded on as well as all the other stock suspension mounts. Couple of years ago I had it rebuilt by a local shop with moser axles and a eaton limited slip posi and 4.10 gears. Drum brakes included. I haven't driven the car much since the rebuild a couple years ago, maybe 5000-6000 miles on it. I'm parting out the car.
Also, I measured from backing plate to backing plate and got 56". IIRC that doesnt quite line up with the stock length, but I think the brakes/axle studs on this one are longer maybe than a regular 3rd gen rear because under the car it looks stock. Below is a pic of the car from the rear with stock 16x8 IROC's and stock size tires and you can see where it sits with the wheel well.
$1250
$1250
Re: KY - 12 bolt - bolt in for 3rd gen
im in ky and i am interested. Can you text or email me pics thank 859-663-1114 jason.terrell351@gmail.com
Finally got it out and pictures. It comes as you see: full rear end, drum brakes, brake lines, emergency brake cables, sway bar, lug nuts, torque arm bolts and nuts.
Price drop: $1250
Price drop: $1250
Terrell351
Jun 13, 2021 01:13 PM
ambainb
Apr 25, 2016 09:21 PM
