world s/r heads
Car: firebird
Engine: 355
Transmission: T-5 NWC
Axle/Gears: 4.11
world s/r heads
They only have a fiew miles on them and are set up for a 1.8 inch spring height. Originaly set up for comp cams 986-16 springs. -67cc combustion chambers -2.02 and 1.6 valves
$400 obo. willing to trade for other parts like a ,31 spline 9 inch locker, m/t 275/50/15's
Car: firebird
Engine: 355
Axle/Gears: 4.11
Re: world s/r heads
bump. Just realized I posted these heads back in 08. Cant believe I have had these on the shelf that long. Here is one of the posts from when they were still on the car and for sale
ran a 13.16 @ 110 with these heads on a 350 with flat tops, a comp roller cam with 212/218 duration at .050 and 487/495 ,airgap(not an RPM-AIRGAP) intake ,650 edelbrock,NWC t-5 trans,3:73s and radials
Car: firebird
Engine: 355
Axle/Gears: 4.11
Re: world s/r heads
1991sleeperthese were fairly oily when I put them on the shelf. I cleaned em up wit sum PB Blaster n a scotch bright quick dis afternoon. I did find a good set of hyd roller springs that I can add for another $100. I know they are not AFR's but for $500 with roller cam springs added they are still much better than L98 heads.
Car: firebird
Engine: 355
Axle/Gears: 4.11
Re: world s/r heads
irocdarnie... The heads have a 170cc intake runner.
Hey guys copy/paste and search --- comp cams xr264hr-10 dyno sheet---
this is the same set up I had in my car with these heads. Pulled a 13.16 leaving the line @idle. 330hp and 420tq is stock LS1 power and verry streetable. With a little bit of converter and good traction the torque should get you into the 12's.
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
Car: firebird
Engine: 355
Axle/Gears: 4.11
Re: world s/r heads
irocdarnie- The shipping would be $125
lameusername- The exhaust ports are square and the shipping would be $95
92projectcamaro
Jan 18, 2016 08:00 AM
