[Sold] 355 Fresh Rebuild [DELETE]
Old Jan 5, 2014 | 03:23 PM
jdracer13's Avatar
Car: 1982 Camaro
Engine: LTX Carb
Axle/Gears: 3.42 Posi
Rebuilt Long Block SBC 350 never run:
-L98 Cast Iron heads
-RV cam
-One peice rear main seal
-Cast 4.030" pistons
-Rods checked
-Block and Heads were cleaned and blasted
-Crank magnafluxed and polished
-Valve job 3 angle
-New seats
-Heads Surfaced
-Was a marine engine
-Includes Dist and Valve covers
New
-RV Cam
-Valves
-Springs
-Lifters
-Head bolts
-Pistons and Rings
-Oil Pump
-Timing Gears/Chain
-Bearings and Gaskets
Needs
-Intake
Asking $1000
Call
724-766-5235
Old Jan 5, 2014 | 07:04 PM
crossrush's Avatar
Car: 1986 Iroc z
Axle/Gears: 3:42
Re: 355 Fresh Rebuild
Do you have the cam specs? Is shipping available?
Old Jan 5, 2014 | 07:49 PM
jdracer13's Avatar
Car: 1982 Camaro
Engine: LTX Carb
We can ship it but we must have full payment first. It will more than likely have to go via freight. The cam that I believe we used was a Melling M-Select MTC-1.
Right From Summit's website:
Cam Style:Hydraulic flat tappet
Intake Duration at 050 inch Lift:204
Exhaust Duration at 050 inch Lift:214
Duration at 050 inch Lift:204 int./214 exh.
Advertised Intake Duration:278
Advertised Exhaust Duration:288
Advertised Duration:278 int./288 exh.
Intake Valve Lift with Factory Rocker Arm Ratio:0.420 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio:0.443 in.
Valve Lift with Factory Rocker Arm Ratio:0.420 int./0.443 exh.
Old Jan 5, 2014 | 08:00 PM
crossrush's Avatar
Car: 1986 Iroc z
Axle/Gears: 3:42
how flexible is your price?
Old Jan 5, 2014 | 08:17 PM
jdracer13's Avatar
Car: 1982 Camaro
Engine: LTX Carb
Firm the remainder of the bill that was owed on the engine was 12XX.XX.
Old Jan 6, 2014 | 01:27 PM
mmiller61's Avatar
Car: 1989 Camaro RS
Engine: 383 STROKER
Transmission: T-56 SIX SPEED
Axle/Gears: 4TH GEN SS
What would the HP est be for this with a std iroc-z tpi set-up? also what would an est. for freight charges to zip code 48317- Thanks for your time
Mark
Old Jan 6, 2014 | 01:32 PM
Jonesyfxr's Avatar
Car: 85 Silver Iroc, 79 Camaro
Engine: LB9, 500+ ci BBC
Transmission: 700R4, th400 with brake
Axle/Gears: 3.42, hand made 40 spline 9"
Just to give anybody looking a little info on that cam. I tuned up a 72 Chevelle with that identical cam in a rebuilt L48 350. The cam had a nice idle with great throttle response.
Old Jan 6, 2014 | 07:27 PM
jdracer13's Avatar
Car: 1982 Camaro
Engine: LTX Carb
Mercury Rated this engine at 260hp with the marine camshaft. I would say it is like the L98 350 tpi 255hp with a mild cam is the best thing to describe it.
Old Jan 8, 2014 | 03:57 PM
jdracer13's Avatar
Car: 1982 Camaro
Engine: LTX Carb
Sold! Please delete.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
83 Crossfire TA
Sep 8, 2015 12:06 PM
Silver Spear
South East Region
Silver Spear
South East Region
Sep 8, 2015 11:59 AM
mantaguy
Sep 2, 2015 10:42 PM
