Removed
Car: 1984 Firebird SE
Engine: 388 sbc, Brodix Track 1s
Transmission: turbo 350 transmission
Axle/Gears: 4.10 gears
Re: Moroso drag springs
How many coils did you cut and will it sit lower the stock having a sm blk in the car?
Ok, thanks anyway but that is lower than I wanted. I actually need to raise my front as I have used v6 spring for so long and not getting the proper weight transfer I need.
Car: '89 Firebird
Engine: 7.0L
These have way more travel than the V6 springs. That's the whole point of them. The springs are so long that I had to compress the springs in two stages to get installed in car. Compress as far as possible just to get it partially hooked in the spring cup, and then compress again to set in place and bolt on the strut. It measures 15.5 inch free length.
