[Sold] AFR 190RE heads
Old Jun 22, 2014 | 05:14 PM
TXBowTie40's Avatar
AFR 190RE heads
190cc runners, 66cc chambers, angle plugs, 2.05/1.60 valves
Picked these up two years ago, got busy with my job so was never home to use them. Now I'm clearing out parts, these are the first to go.
Located in White Deer, TX, 79097. I paid $1200 when I bought these, they were literally taken out of the shipping box to inspect them, then reboxed and there they have sat since Feb 2012. I am asking $1000 firm, shipping should be around $50.
Not wanting to trade for anything as I have too much stuff sitting around my house and garage as it is.
More pics available upon request.
Attached Thumbnails AFR 190RE heads-end-part-number.jpg   AFR 190RE heads-combustion-chamber-1.jpg   AFR 190RE heads-top-view-head-1.jpg
Old Jun 27, 2014 | 01:05 AM
RyanJB's Avatar
Car: 92 Firebird, 91 Trans Am
Engine: L31 with HSR, LB9
Transmission: 700R4, 700R4
Axle/Gears: '99 10 bolt 3.90, '01 10 bolt 3.42
Re: AFR 190RE heads
What's the difference between the AFR 190s I could buy from AFR and these?
Old Jun 27, 2014 | 06:56 AM
TXBowTie40's Avatar
Re: AFR 190RE heads
I have emailed AFR to see if the "RE" designation means anything. I will get back with you on this when I get their response.
Other than the ones you purchase from AFR being brand new and my set being used, I don't have a clear answer.
Bear with me, I don't know how long they will take in responding.
Old Jun 28, 2014 | 04:47 AM
RyanJB's Avatar
Re: AFR 190RE heads
Yeah I'm just curious about the "RE" as I have never heard of that before. If its basically identical or close enough to what I'd get from them I'll be interested.
Old Jun 28, 2014 | 07:09 AM
1991sleeper's Avatar
Car: 1991 firebird
Engine: TBI 305 (built)
Axle/Gears: 4.10
I'm pretty sure AFR heads usually have about a 3" logo on the front of heads covering that whole front accesorry pad...I could stamp those letters in with letter punches
91' bird 305 TBI T-5, trick flow 175 cc heads, 4.10 gears, lots of suspension upgrades......... 24mpg @ 2300rpm hwy 65mph ........ 8.63@ 85mph 1/8th on street tires... 8.000's soon
Old Jun 28, 2014 | 07:14 AM
Car: 1991 firebird
Axle/Gears: 4.10
Like so ... Re = racing eliminator
Old Jun 28, 2014 | 09:39 AM
rongreen's Avatar
Car: 1938 Chevy 2 dr Sedan
Engine: Dart400 AFR190 TPIS ZZ409 Big Mouth
Transmission: Gearstar 700R4 level 4
Axle/Gears: Moser 12bolt-Det Trac loc 3:42
Re: AFR 190RE heads
I have a set of old AFR 190 purchased new from AFR around 1992. They have smooth machined pads on the ends with no AFR logo. They look exactly like the ones pictured here except they have 190 on them not 190 RE. The combustion chambers are 74cc.
Old Jun 28, 2014 | 03:46 PM
Car: 1991 firebird
Axle/Gears: 4.10
Mabwy that's the difference in re ? Smaller Chambers and 2.05 instead of 2.02 valves ?
Old Jun 28, 2014 | 08:40 PM
TXBowTie40's Avatar
Re: AFR 190RE heads
I haven't been ignoring the question, but I haven't heard back from AFR yet. I will call AFR tomorrow morning.
As to whether they are legit AFR heads, they do have the "A" cast into the surface of the heads like most if not all AFR heads I have ever seen.
Here is another photo of that, notice the "A" cast in between the exhaust ports.
Old Jun 29, 2014 | 07:08 AM
rongreen's Avatar
Re: AFR 190RE heads
I am looking at the photo are they angle plug heads? My AFR 190 are not angle plug heads.
Old Jun 29, 2014 | 07:21 AM
TXBowTie40's Avatar
Re: AFR 190RE heads
Yes, they are angle plug heads
Old Jun 30, 2014 | 09:27 AM
TXBowTie40's Avatar
Re: AFR 190RE heads
Okay, finally got through to AFR. The tech I talked to could only tell me they weren't their newer heads (duh), and little else.
I looked at the porting centers listed on the AFR website, attempted to call Slover's, without success (they don't open til 10AM for anyone else trying to reach them by phone), then called Frankenstein Racing Heads in DFW.
The man I spoke to said they were likely first generation AFR heads, he had no idea what the "RE" signifies (something AFR stamped on them that meant something back then, no idea what), and they are good street heads, but that if someone is wanting to build an actual race engine, there are better versions available now (which makes sense......just look at their website to see how they are evolving and improving their designs).
So what these heads appear to be, from professionals in the industry, are 1st generation AFR heads, probably originally cast in the 90's. Beyond that, I cannot seem to find any further information.
Hope this helps............
Old Jul 1, 2014 | 09:12 PM
TXBowTie40's Avatar
Re: AFR 190RE heads
Email from AFR I received today:
Eddie,
You have an older (10+ years) set of our 190cc Race heads. This is a relatively dated design, however it was a very good casting. Being that they are this old, you should have the combustion chambers CC’d and intake runner flow benched to confirm #’s. There is no way to tell what may have been modified once they left AFR.
Hope this helps. If you have further questions on our product please call us, toll free 877-892-8844."
Old Jul 2, 2014 | 11:40 PM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
Re: AFR 190RE heads
I was just going to chime in and saw that AFR finally got back to you about this. My AFR heads were made the year before they switched to their new series and don't even look like these so they would def be older AFR heads. Most likely they flow ~250 cfm at 0.500 lift.
Old Jul 3, 2014 | 11:28 AM
TXBowTie40's Avatar
Re: AFR 190RE heads
I called and made an appt to have the heads cc'd and flowed. Supposed to take them in on Monday, I will post the specs and flow numbers then.
Old Jul 3, 2014 | 11:57 AM
3rd gen Will's Avatar
Car: 91 Z28, 2000 T/A
Engine: SBC 355, LS1
Transmission: T56, T56
Axle/Gears: 10bolt 3.73, 3.42
Re: AFR 190RE heads
I wanna also chime in here and confirm that these are older AFR's. The large A cast into the side of the head designates their casting. I have a set of their 180s, Which also have smooth surfaces on the ends with hand punched numbers/letters in the end of the head. These are their "Pre" Elimator heads and from my understanding are very close in numbers and performance capability of the newer design. I am curious to see the numbers yours come up with as a buddy of mine has a set of these 190s on a 406.
Old Jul 3, 2014 | 02:47 PM
rongreen's Avatar
Re: AFR 190RE heads
I purchased the AFR 190 heads years ago. I doubt if there a whole lot of a difference between the 190
and the 195 Eliminator street heads. Now if I was drag racing and looking for a couple of tenths that would be different.
The tech rep said that they were ok when I ordered a new ZZ409 cam for the new Dart 400 build.
Old Jul 12, 2014 | 12:43 PM
TXBowTie40's Avatar
Re: AFR 190RE heads
Leaving this afternoon to go work a well about 4 hours from home. Not sure how long I will be gone, just guessing about 3-4 weeks.
Just letting anyone who might be interested in these heads what is happening as I don't always solid internet access out on these jobs.
Old Aug 12, 2014 | 06:40 PM
TXBowTie40's Avatar
Re: AFR 190RE heads
Taking these off the board due to a lack of interest. Thanks for the feedback and comments from members while I had them listed.
I'll hold on to them a while. Who knows, I might be in a position sometime in the future to start with this hobby again and be able to use them.
Old Aug 13, 2014 | 01:36 PM
Re: AFR 190RE heads
Did you ever get them flowed?
Old Aug 13, 2014 | 05:35 PM
TXBowTie40's Avatar
Re: AFR 190RE heads
Yes, had them flowed last month. PM'd the numbers to a member who seemed interested, haven't heard from him in over a month.
Lift Int. Exh.
.200 130.3 109.0
.300 194.3 139.8
.400 242.9 163.5
.500 258.3 175.4
.600 260.7 181.3
.700 263.1 189.6
Old Aug 27, 2014 | 10:38 AM
Re: AFR 190RE heads
Right on, I assume they used a 4" pipe? I am just curious b/c my heads should have similar numbers.
Old Aug 27, 2014 | 11:48 AM
89gta383's Avatar
Car: 89 GTA
Engine: 383
Transmission: 4L80E
Axle/Gears: 12 bolt-3.73
For the price these are hard to beat. I have these same heads that have been ported by Lloyd Elliot and they flow around 285-200 at .600 lift. I have the smaller 2.02 valves also.
Old Aug 28, 2014 | 03:40 PM
Steve Mack's Avatar
Car: 87 Iroc
Engine: modified 350
Transmission: high performance built 700R4
Axle/Gears: Strange S60 3:73
Re: AFR 190RE heads
AFR's have always been top of the line heads.These are very good heads and well worth the money.If I had the cash right now these would be mine.These heads with the right setup can easily make 500 HP.
Old Sep 3, 2014 | 05:10 AM
karl's-92'-z28's Avatar
Car: Too many cars
Re: AFR 190RE heads
They are non vortec style?
Old Sep 3, 2014 | 09:11 AM
TXBowTie40's Avatar
Re: AFR 190RE heads
That is correct, these are non-Vortec, not L98, they use the old style bolt pattern.
Old Sep 3, 2014 | 08:07 PM
TXBowTie40's Avatar
Re: AFR 190RE heads
Probably gonna be heading out in a few days, so in another attempt to move these heads, I'll drop the price to $800 plus shipping, which should be around $50.
Old Sep 4, 2014 | 03:08 PM
TXBowTie40's Avatar
Re: AFR 190RE heads
Heads are SOLD. Thanks for the feedback and comments.
norcalz28
Northern California
26
Dec 7, 2016 12:49 PM
92projectcamaro
Jan 18, 2016 08:00 AM
New2Chevy
Sep 28, 2015 12:35 AM
z28guy134
Sep 1, 2015 11:50 PM
