[IL] fs LS front brake conversion
Old Jul 8, 2014 | 09:33 AM
prossi's Avatar
includes full calipers, brackets, modified spindles and rotors. you would need hubs or have your rotors cut down.
$225 plus shipping please text for pictures 630 659 8879
Old Jul 9, 2014 | 07:02 AM
ownor's Avatar
Car: 84 TA / 89 Formula
Engine: LS1 / L03
Transmission: T56 / 700R4
Axle/Gears: 3.73 / 3.27
Re: fs LS front brake conversion
care to elaborate please?
Old Jul 9, 2014 | 09:05 AM
prossi's Avatar
you would need these which can be made by cutting a stock rotor or purchasing them pre made
Old Jul 9, 2014 | 09:20 AM
ownor's Avatar
Engine: LS1 / L03
thanks, so i gather the hub mating face to the rotor is a different thickness than on our 3rdgen hubs?
Old Jul 9, 2014 | 11:06 AM
Blue 90 RS's Avatar
Car: 1990 Camaro RS
Engine: 5.0L
Transmission: WC T5 5-speed
Third gens don't have a separate hub. It is cast integral with the rotor, so the hub/bearings/rotor/studs come as one unit if you replace factory with factory. Fourth gens have separate hubs & rotors, but those hubs won't fit third gen cars, thus the need to modify the third gen hub/rotor casting into a "hub only". This requires cutting the "rotor" portion off, leaving only the "hub" portion to be used in conjunction with the parts he is selling. Hope this helps.
Old Jul 10, 2014 | 03:24 PM
silentkillzr's Avatar
Car: 1984 Firebird (89 Formula Clone)
Engine: 357
Transmission: m29 T56
Axle/Gears: 3.27 9 bolt Borg Warner.
Ill buy this kit. Pm'd..
Old Jul 11, 2014 | 10:07 AM
prossi's Avatar
pm replied
Old Jul 25, 2014 | 05:06 PM
89mulletbird's Avatar
Car: 89 GTA
Engine: 6.0L Procharged
Axle/Gears: 4.10
Can you use non-1LE rotors to make hubs, or must use 1LE rotors?
Old Jul 25, 2014 | 05:13 PM
Base91's Avatar
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Axle/Gears: 9-bolt 3.27 & PBR
Depends on what brakes you're going to use. I know C4 HD requires 1LE but from what I've read most others (including LS1) don't. Check lukeskaff.com for lots of great info including hub making. You can get hubs from flynbye.com
Old Aug 3, 2014 | 10:03 PM
Car: 89 GTA
Axle/Gears: 4.10
still avail?
Old Aug 7, 2014 | 10:00 PM
alex722607's Avatar
Car: 1988 Pontiac Transam GTA Notchback
Engine: 2003 Chevy 5.3 Vortec (325 cu)
interested, do you still have this?
Frozer!!!
Jan 19, 2024 04:55 PM
Scorched1984
Wheels and Tires
66
Apr 16, 2016 06:56 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
stalkier
Aug 13, 2015 12:59 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
