[PA] 400 SBC Long block for sale
I have a 400 SBC Long block for sale. Motor is bone stock other than the cam but I don't know the specs. It is currently in the car running but has a rod knock. I will be pulling the motor out over the weekend. I believe at some point the motor was rebuilt however I don't know the mileage. Motor does not smoke so you could just replace the crank, bearings and the bad rod and call it a day if you want.
Block casting # 3030817 1973-76
Motor is being sold without the intake manifold, carb and distributor. Asking $475 B/O
Located in Hatboro, Pa
Car: current project : 85 hard top TA
Engine: BUILDING : 409 SBC
Transmission: TRANZILLA
Axle/Gears: Dana 44: 3.92 spool
Re: 400 SBC Long block for sale
I have 4, engine projects going rite now. & 3 of them are 400's.
other wise i would get this one from you .
why don't you just build it?
Rite on, hope you get the supercharger
A lot of people are scared of the 400's, it might help if you tare it down and get the block checked . the heads are junk, unless someone just needs a stock replacement . if memory serves me correct, that is a 2 bolt block?
, A lot of people are scared of the 400's, it might help if you tare it down and get the block checked . the heads are junk, unless someone just needs a stock replacement . if memory serves me correct, that is a 2 bolt block?
MoJoe
Sep 24, 2015 09:12 PM
