[NY] MISC OE/Restoration parts 88GTA
Car: 1988 Trans Am GTA
Engine: 6.0 LQ4
Axle/Gears: 3.43
Since I am going the resto-mod route with my car I have decided to sell off some of the OE stuff I have lying around. Was going to save it all, but I don't think realistically myself, or anyone in the future, is going to go through the effort of putting an LB9 back into a third Gen. Most of this stuff is OE and in really good shape, there are a few performance parts. Prices DO NOT include shipping unless specified. I'm also going to list the stuff a few at a time in this thread (a lot of the stuff I have to get to in storage) so check back for updates or PM me if you are looking for something specific. I'm going to give TGO first crack at the stuff because I would like to see it go to someone who appreciates third gens, but at some point it will start going on ebay if it isn't moving.
TPI fuel rail W/ Holley adjustable FPR and new 9th Injector $200.00
Clean TPI Plenum $50.00
OE replacement PCM and bracket for LB9 engines (less than 100 miles on car) $125
Plastic Dizzy Cover $25.00 Shipped
Washer bottle with pump. Pump worked when removed but that was 6 years ago $15.00
Engine: 6.0 LQ4
Axle/Gears: 3.43
Re: MISC OE/Restoration parts 88GTA
Aluminum Bow tie center bolt valve covers, one small dent in one of the corners (second picture) $50.00
Accel ignition coil, used for less that 1000 miles $30.00 shipped
Brake vacuum booster, very light surface rust, roughly 3 years old, used for around 4000 miles $50.00
OE Firebird WS6 springs, these are factory original GM units with 11,000 miles on them $125.00
Generic wonder bar (no idea where I even got this) $25.00
Water pump, painted black, 100 miles on it $15.00
Engine: 6.0 LQ4
Axle/Gears: 3.43
Stock TBI throttle body with air foil, comes exactly as pictured with the exception of I will put the bottom piece back on that is currently on the 52MM $100.00 *SOLD*
Professional Products 52MM T/B (Part#69705). Comes as pictured minus the bottom piece which will be going back on the stock T/B $185.00 *SOLD*
Stock MAF, 11K on it SOLD
MAF Bracket $25.00
MAF Bracket $25.00
LT1Formula
20
11-14-2015 12:02 AM
3rdgenparts
08-05-2015 11:57 PM
