[NJ] Rear weight jacks
Car: 87 TA clone
Engine: 70/70 Turbo 5.3 LS
Transmission: bullet proof 2004R
Axle/Gears: ford 8.8, 3.55 gears
Rear weight jacks
Made my own weight jacks, Steel riser allows 2.5" of adjustment and lays onto of the stock spring mount on the rear and allows use of any 5.5 - 5" racing spring. I currently have AFCO 200lb on it and still have all the original AFCO boxes and warranty info. The springs have less than 500 miles on them. You get the weight jacks, and both springs for $130 plus the ride. It takes 5 min to install them after you jack up the car and unload the rear. Adjustments are just as easy. Plus since it uses standard springs you have a limited choice of spring selection!
located in NJ.
Installed on my 87.
located in NJ.
Installed on my 87.
Car: 87 TA clone
Re: Rear weight jacks
Getting shipping g quotes tmrw from UPS and USPS.
Car: 87 TA clone
Still got them. Need zip for shipping
Car: 1991 firebird XS
Engine: 5.7 tbi
Transmission: stock 700r4
Axle/Gears: 9 bolt 3.23
91950 those should fit in a flat rate box since they are 5 in springs. I shipped other springs in a flat rate box that were 5 in... it was like 25 bucks to NY
Car: 87 TA clone
Car: 87 TA clone
Yea… figured you didn't want them as you didn't respond. Heres a screen shot of my sent PMs… this is on 1/23/15… quote then was $32. gotta see what I'm going to do with these… gona mock up the coil overs soon and if they leave me with less room for exhaust then might have to keep the weight jacks.
Car: 1986/90 camaro
Engine: 350 tpi
Axle/Gears: 3.73 gears. POSI
interested if still available, shoot me a txt 4147088659 or dm on here, thank you!
ambainb
Apr 25, 2016 09:21 PM
