T56 cable drive
Car: 90 Camaro
Engine: 418 LS3 whipple charged
Transmission: Magnum T56 w/ Street Twin
Axle/Gears: 3.27 9 bolt
T56 cable drive
Selling the cable drive converted tail housing from my old T56. Would like to trade complete tailhousings with someone +$150.
Car: 90 Camaro
Re: T56 cable drive
It only has a mechanical drive now. I have a 2 piece speedo cable that I installed a VSS as the joint for the cables. I'm including this. That way I had both electronic and cable outputs. tail housing is easy to remove. support the trans, remove the shifter, remove the shifter cup from the shift rail, remove the trans mount, unplug any harness's from tailhousing. then unbolt the tail housing from the trans. you would need to remove one snap ring from the tailshaft so the VSS ring can be swapped with the new speedo gear.
Car: basic third gens
Engine: that I like
Transmission: to restore
Axle/Gears: and enjoy
Re: T56 cable drive
How soon are you wanting to get this done? I'd like to swap, but I won't be home for a couple more weeks.
Car: 90 Camaro
Re: T56 cable drive
Not sure if it's still for sale. A buddy of mine wants it for his 70 Chevelle. I'll update this thread as soon as I know
Car: 90 Camaro
Re: T56 cable drive
Yes I got your message and when I called my buddy to go get it he started to rethink letting it go. He has first dibs on it. I'll let you know what's going on this week
ambainb
Apr 25, 2016 09:21 PM
db057
Aug 11, 2015 10:11 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
