[CA] TPI motor, LS1 motor, TPI/auto harness, LS1 Fbody-M6 wiring harness
Old 02-20-2015, 08:39 PM
JayBoCC2's Avatar
Car: '88 trans am GTA
Engine: 5.7L 355 TPI L98
Axle/Gears: eaton posi 3.73 gears
mildly-built 350 TPI takeout of my 88 GTA? Need to make room in garage to complete my LS3/T56 swap.
350 TPI:
bored 0.030 over (355)
Edelbrock Performer 6085 Alum heads - Stage 1 ported and flowed by TPIs (have papers from when ported and flowed),
TPIs ZZ9 hydraulic roller cam by Crane - GRIND#SB-ZZ-9-HR12
1.5/1.6 roller rockers + springs by Comp
10.5~ compression.
Forged Pistons w/ moly rings
Unported SLP runners. (on motor)
TPIS large tube aluminum runners (off motor, vaccuum leak)
52mm TB.
TPIS Ported Plenum 52mm.
tpi base, top and large tube runners [have vacuum leak] are powder coated.
Adjustable fuel pressure regulator.
MSD coil,
MSD distrib,
Accell 10mm wires.
Air delete.
March Alum Underdrive pullies.
Edelbrock carb eo shorties [powdercoated - need recoated].
MAF [descreened and gutted]
Moroso Oil pan
Edelbrock Water Pump
maybe more to list...
Have receipts for every part listed here from the day it was purchased.
Will provide copies of documents to the buyer.
Also have other stuff avail:
- full T5 swap avail (1988 1352-176 WC trans, clutch, fw, bellhousing, pedals, Master/Slave) (88-96k on T5 - not behind 350 for more than 5-9k miles at max, 88k behind stock 305 when pulled) - $900 - SOLD
- LS1 Prev Owner claimed 40k on block, running when pulled [minus: ps pump, alt, water-pump, flywheel, coils] (has broken oilpan threads on block but doesn't leak oil - machine shop said $300 to repair) - $1500
- LS1 -m6 wiring harness - $400
- TPI harness and 165 ecu - multiple flashes inc stock. - $400
- logging/prom adapters/burning/reading gear from moates and and old pocket programmer. - $120 - SOLD
Everything has already been removed from car.
Will NOT part out the motor. You want to part it you buy it whole and part it out yourself.
Located in 94089
Serious offers please. PM here or Text 4O2-321-7388
edelbrock performer 6085 alum heads - TPIs stage 1
a couple of the parts on a recept and the zz9 cam specs
Attached Thumbnails TPI motor, LS1 motor, TPI/auto harness, LS1 Fbody-M6 wiring harness-10842310_10204992783271732_8962533442610591881_o.jpg   TPI motor, LS1 motor, TPI/auto harness, LS1 Fbody-M6 wiring harness-10997722_10204992783871747_8357367226793624177_o.jpg   TPI motor, LS1 motor, TPI/auto harness, LS1 Fbody-M6 wiring harness-10986866_10204992784591765_5815885494956127094_o.jpg   TPI motor, LS1 motor, TPI/auto harness, LS1 Fbody-M6 wiring harness-img_20140524_153655.jpg   TPI motor, LS1 motor, TPI/auto harness, LS1 Fbody-M6 wiring harness-img_20140524_153708.jpg
Last edited by JayBoCC2; 05-03-2015 at 01:37 AM. Reason: Updated definitive block parts list based on receipts. updated sold.
Old 02-21-2015, 12:54 AM
wildmon69's Avatar
Car: 86 T/A/1990 Firebird
Engine: 5.3 L33 pt7675 / Ls1
Transmission: 4L80E/T56
Axle/Gears: 3.73/4.10
Re: TPI, T5 and LS1 swap combos, harness, prom gear
Was that ls1 m6 harness already adapted to work in a thirdgen?
Old 02-21-2015, 01:06 AM
JayBoCC2's Avatar
No, unmodified. I was gonna use this but I went with gmpp LS3 plugnplay control kit.
Old 02-28-2015, 05:33 AM
JayBoCC2's Avatar
list still up for sale.
open to reasonable offers.
Old 02-28-2015, 08:13 AM
Ta Re Ser's Avatar
Car: 88 GTA Ta
Engine: 5.7 TPI
Any interest in selling the headers and possibly the runners
Ta Re Ser's Avatar
Car: 88 GTA Ta
Engine: 5.7 TPI
Nvm just realized you don't want to part.
Old 03-04-2015, 10:54 PM
jcaulton's Avatar
Car: 1986 Z28
Engine: 5.0 TPI
Axle/Gears: 2:73
Any suggestions on how to get the t5 setup to Chicago?
Old 03-05-2015, 03:41 AM
JayBoCC2's Avatar
I used uship.com to ship my LS3 to me. Guy stuck it to a pallet and it was picked up at his shop and dropped by gate and pallet jack into my garage. Since i'm a house it'd have to be lift gate pickup but it was still not terribly expensive at estimated 420lbs weight, they even refunded me for the actual weight of the freight. My zip code is 94089
T5 only weighs about 75lbs. May get away with shipping it in a wooden crate. I can crate it or palletize it.
Old 03-22-2015, 09:11 PM
JayBoCC2's Avatar
Bump - Double checked tags on T5 and it is a WC unit.
Old 03-23-2015, 07:49 AM
gcj280's Avatar
Car: 1987 Iroc Z
Engine: 355 TPI Fully Built
Transmission: Borg Warner WC 5-Speed
Axle/Gears: Stock Posi Rearend
how much are you looking to get for your tpi engine (ballpark)?
Old 03-23-2015, 12:34 PM
Zed/28's Avatar
Car: 89 Z
Axle/Gears: 10 bolt 3.23
I'm interested in the Moates gear. Do you have pics of what's included ?
Old 03-23-2015, 01:40 PM
JayBoCC2's Avatar
Old 03-25-2015, 11:48 AM
Zed/28's Avatar
Car: 89 Z
Bump it up for pics of the Moates parts.
Old 03-25-2015, 11:59 PM
JayBoCC2's Avatar
added pic of moates prom gear...
left is usb obd1 adapter and right is usb prom burner with ZIF socket.
Old 03-26-2015, 12:35 AM
89Zleeper's Avatar
Pm me I'm located in Ca interested in motor. Text 5109358878
Old 03-26-2015, 11:51 AM
Zed/28's Avatar
Car: 89 Z
Thanks for the pic. Not exactly what I need . Good luck with the sale !
Old 04-04-2015, 11:06 PM
JayBoCC2's Avatar
bump ... went through my receipts and updated all the mods to the TPI motor.
Old 04-18-2015, 01:44 PM
JayBoCC2's Avatar
Moates.net Chip burner, obd1 pc adapter and piggy back adapter sold and shipped!
Old 04-18-2015, 06:03 PM
EDGE's Avatar
Car: 1987 GTA
Engine: 5.7
Transmission: T5WC
Axle/Gears: 3:27
Re: TPI, T5 and LS1 swaps, TPI/auto harness, LS1 Fbody-M6 wiring harness
Is the T5 still available?
Old 04-25-2015, 01:07 AM
JayBoCC2's Avatar
Yes, but i will not part, if you were the one looking to buy just the clutch.
Old 04-25-2015, 06:27 AM
EDGE's Avatar
Car: 1987 GTA
Engine: 5.7
Transmission: T5WC
Axle/Gears: 3:27
I'm interested in the whole T5 swap kitr
Old 04-26-2015, 11:52 PM
sac92transam's Avatar
Car: 92 convertible t/a and 68 firedbird
Engine: 305/402
Transmission: 700r4/turbo400
Those the ls1 come with the tranny?
Old 04-27-2015, 12:10 AM
JayBoCC2's Avatar
What?
Old 04-28-2015, 05:44 PM
Engine: 305/402
sorry i what i was trying to say does the LS1 come with the T56? what else?
Old 04-28-2015, 07:48 PM
JayBoCC2's Avatar
No, the price is just for the LS1. I'm using the T56 with my LS3.
Old 04-30-2015, 10:15 PM
JayBoCC2's Avatar
T5 sale pending payment and shipment.
Old 05-03-2015, 01:38 AM
JayBoCC2's Avatar
Re: TPI motor, LS1 motor, TPI/auto harness, LS1 Fbody-M6 wiring harness
T5 sold and shipped.
Old 05-17-2015, 11:38 AM
Slowridr's Avatar
Car: 1987 GTA Vert & 1991 GTA 5 Speed
Engine: 87 GTA-L98 91 GTA LB9
Transmission: GTA-700R4 & GTA T5
How much for the TPI motor?
Old 05-17-2015, 03:11 PM
JayBoCC2's Avatar
Make me a reasonable offer. Needs rebuild and want it to go to a good home.
crt454
Interior Parts Wanted
06-23-2017 02:25 PM
Caspar
06-19-2016 11:19 PM
Ikes 91Z
12-09-2015 03:49 PM
Reddeath210
10-06-2015 08:20 AM
Sanjay
08-12-2015 03:41 PM
Quick Reply: [CA] TPI motor, LS1 motor, TPI/auto harness, LS1 Fbody-M6 wiring harness
