[IA] Re-conditioned AFR 185's with Titanium valves, Comp dual valve and titanium retainers
Old 03-20-2016, 05:01 PM
gixxer92's Avatar
Car: 1986 IROC, 2017 Silverado
Engine: 7.0L, 6.2L
Transmission: Tremec Magnum, 8L80
Axle/Gears: 3:23, 3:55
The have been sitting on the motor since i had the work done by a local shop, lapped, seats, etc... I will not be using now to put in the car since I'm converting to an LS motor.
These are the older version of the AFR 185's and are not drilled for centerbolt valve covers. You can have it done if you want when you purchase them.
Complete with the titanium valves, titanium retainers and Comp 26925-16 springs that support 0.625 of lift of the 292XFI 07-468-8 ($185 new).
The motor with the heads were built for hi RPM, I'm asking 2000 obo for the heads.
For the $2000 you also get the SBC ARP head studs and nut, 12 pt, w/ undercut studs. The kit part number is 234-4707 @ $230
These parts have only been installed, rockers never tightened on a never fired 383 sbc.
I figured I'd part it out since there seems to be a lack of interest for the whole motor at $6500...
Attached Thumbnails Re-conditioned AFR 185's with Titanium valves, Comp dual valve and titanium retainers-20151021_163507a.jpg
Last edited by gixxer92; 03-21-2016 at 02:42 PM. Reason: Adding a photo, no behives they are comp dual valve springs
Doug Phillips
09-23-2016 09:25 PM
dennisbernal91z
04-14-2016 05:42 AM
codyscamaroz28
03-18-2016 12:04 AM
AmpleUnicorn88
Brakes
03-15-2016 07:04 AM
transamrob86
03-08-2016 12:43 PM
Quick Reply: [IA] Re-conditioned AFR 185's with Titanium valves, Comp dual valve and titanium retainers
