Ls swap motor mount
Car: 1982 Z28, 1991 RS
Engine: 350 Carbed, 305 TBI
Transmission: 700r4, t5
Axle/Gears: 3.23s posi Limited Slip, 3.08 posi
Ls swap motor mount
anyone ever use these motor mounts? just ordered them for my build im doing a 6.0/700r swap to my 82 z28
http://www.ebay.com/itm/1982-92-3rd-Gen-F-Body-Engine-Mount-Adapter-Swap-LS-LS1-Camaro-Firebird-14029A-/221926085350?_trksid=p2047675.l2557&nma=true&si=6CJ2KJegV%252B7HT87YVSAjTQ4hnTk%253D&orig_cvip=true&rt=nc
Car: 92 camaro RS
Engine: LSA
Transmission: Magnum F
Axle/Gears: TNT 8.8 wavetrac 3.31
Re: Ls swap motor mount
This is the first time I have seen them. I was going to buy the plates so I can reuse the sbc factory mounts plus there only $30 bucks but if I needed all new mounts I would go with something like you got.
yea im gonna use these with the 4th gen clam shell
Car: 92 Camaro RS
Axle/Gears: 10bolt w3.42 Torsen
They are a pretty simple mount. I see that kit includes hardware. Factory bolts are metric grade 10.9. GM decided on those for a reason. I replaced mine with new 10.9 grade hardware.
Car: 68,87,99 maros, 07 tbss
Engine: TPI,LS2,LSA,L92
Transmission: T56,T56,T56, 4L80E
Axle/Gears: 12bolts and 14 bolt lol
thats not bad i was gonna get the ones hawk sell, but theses were cheaper lol i paid 70$
And you think i need to use all 8 bolts on the mounts? the dude i got these from didnt include the nuts so all i got is my factory nuts, he gave me bolts but no nuts, makes perfect sense. i seen that the hawks ounts only used 6 like the factory ones what do you think?
As for the brake line I didn't get that far. Ended up selling that project and getting one with a tubular K member. I'll be using those mounts/headers/oil pan on my white Iroc. From what I was told the oil pan should clear the brake lines without needing relocation.
sweet man can i see some pics of your set up? id kill to have a tubular K member an all the goodies along with it lol
Matthew1821
Interior Parts Wanted
Dec 22, 2016 07:06 AM
BOTTLEDZ28
Mar 14, 2016 08:45 PM
