88 GTA part out, NIB SPOHN PARTS
Car: 88 camaro, 87 TA
Engine: 454 stock, built 468 400hp+150 shot
Transmission: WC t5, m29 t56 spec stg3 clutch
Axle/Gears: 9 bolt 2.77, 9 bolt 3.70
Hey guys, unfortunately I haven't had the time to complete this car as I had once hoped. So for now I am parting out what I have and am planning on keeping the shell to build later unless a deal comes along where someone may be interested. The list is as follows:
K(
-Spohn tubular k member and control arms.$
-Spohn rear lower control arms and relocation brackets.$
-Spohn tubular panhard bar as well as the bar that goes above it and bolts to chassis(i forget the name but can post pics tomorrow).$
-Set of upper and lower SOLID LS engine mounts.$120
-Full 8 point Competition Engineering roll cage.$150
-Spohn weld in tubular subframe connectors.$
-KYB adjustable shocks all four corners.
-Eibach lowering kit.$
-BMR strut tower brace.$200
-Solid front upper adjustable shock mounts.$120
-Wonder bar.$80
-Stainless steel brake line kit with braided hoses.$200
-full painless chassis harness.$250
Now for the used stuff:
-Two A/C delete boxes.$150/100
-Explorer 8.8 3.73 w/stock posi 31 spline with kit to accept torque arm mount(needs welded on yet)$400
-Spohn tubular torque arm with trans cross member(t56) and driveshaft hoop.$250
The car currently has a 9 bolt with 3.27(I believe) gears in it with disk brakes that have only 300 miles on em. I have a ton of other stuff as well so please feel free to shoot me a call or text anytime Jake 330-417-4106 I will also post pics and update more pricing tomorrow first thing. Thanks!
K(
-Wonder bar.$80
Transmission: Pro-built 700R4
Re: 88 GTA part out, NIB SPOHN PARTS
What are you asking for the KYB stuts/shocks, and what is the part number for the Spohn subframe connectors?
Car: 89 IROC
Engine: 6.8 HSR N2O
Transmission: TKO 600
Axle/Gears: 9" Moser 3.50 True trac
Is panhard bar adjustable $?
Are lower control arms adjustable? $?
Is K-member for LS or SBC? $?
Car: 88 Camaro
Engine: 355cid
Transmission: 700r
Axle/Gears: 9'' w/ 4.10
Roll cage, wonder bar, lower control arms(if they're red) shipped to 66608 commercial adress? Thanks
LCAs
LCA relocate brackets
Subframe connectors
Chassis harness
Panhard bar and relocation kit
Wonder Bar
ALL SOLD
Subframe connectors
Chassis harness
Wonder Bar
ALL SOLD
Car: 87 GTA Trans Am
Engine: 5.7 350 TPI
Transmission: TCI transmission
Axle/Gears: 4th gen rear end. With 3.83
How much for just two front
Car: 86 Camaro
Engine: 355
Transmission: Powerglide w/brake
Axle/Gears: Currie 9" w/4.56
K member for LS? I'm interested in the K member, a arms, and motor mounts. You don't have any prices for the k member or a arms
