[NJ] 85 drag car partout.
Car: 86 Trans Am, 92 Firebird
Transmission: TKO600, T5
Parting an 85 drag chassis.
***Chassis now being parted
Both battery trays are rust free, will cut out. 30$ each
Decent driverside door some hols on bottom 50$
Good working hatch struts 10
85-90 trans am tail lights, little or no delamination, passenger side reflector strip cracked 80$
Sparco evo2 seat and 5pt harness, nce shape, expired sfi. 200$
Properly sumped factory tank, 2. 1/2npt outlets. 100$
Gas door 5$
I'll cut the roof off the car and remove the cage if somebody wants to try and use it somehow. Pm m
Light weight front bumper support, replaces inpact bar. 40$
85-90 gta bumper cover, no tears overall good shape. 100$
1 7/8x2 hedman hustler Stahl pattern sbc headers with flat 3.5" collectors. Surface rust, totally badass looking. Would fit ankiller small block with matching heads or great Wall hangers for man cave. 250$
Other parts will be available separate if the body doesn't sell
PRICES DO NOT INCLUDE SHIPPING!!!!
Pm or call/text 9082689201
Hunterdon county NJ
-Phil
Gas door 5$
Hunterdon county NJ
-Phil
Re: 85 drag car partout.
Your a little over 2hrs from me, i could drive it to you for less than shipping, but it won't fit in my car and I don't want to drive my Jeep that far either, lol.
Let me see what I can do.
TGO Supporter/Moderator
Car: '88 Formula, '94 Corvette, '95 Bird
Engine: LC9, 355" LT1, LT1
Transmission: T5, Zf6, 4L60E
Axle/Gears: 3.42, Dana44 3.45, 3.23
Is the housing stock width?
-- Joe
-- Joe
Yes
I won't separate it at this price. Sounds like you would be better off just getting a new houses ng and axle package, last time I looked the were still under a grand.
-- Joe
Want a title? Post!
Car: Firebird T/A GTA 88 hardtop
Engine: SBC 350 tpi
No I won't ship overseas, sorry
Yes I will part the chassis
Axle sold
Want a title? Post!
Engine: SBC 350 tpi
Car: 1983 Camaro Z28
Engine: 584
Transmission: TSI Glide
Axle/Gears: Quick performance 9 inch
Very interested in the fuel tank! I didn't see any pics though. Can you send pics of it to me? Nice and clean inside? Rusty?
Pm me and I'll shoot you my email. Thanks!
Pulled the tank, clean inside and out.
Car: 91' camaro rs
Engine: Sbc 327
Axle/Gears: Stock 10 bolt w/posi 3.90 gears
Hi, are those headers stepped? They are for standard sbc heads right? Thanks.
They are stepped 1 7/8 to 2". They are made for these cars, they are for Stahl pattern sbc heads, not standard sbc heads
Coilovers sold
Hood and passenger side door sold
Bump
Car: 1984 camaro z28
Engine: 5.7L
Transmission: T5 s speed
Axle/Gears: Not sure yet
Do you still have the torque arm? How much would it be to ship it to 03561? I am seriously interested in it.
Probably 45-50$ based on the last couple shipments
***Chassis now being parted.
Almost new passenger side trans am fender 100$
Good driverside fender, stress crack right behind headlight 40$
Core support section 100$
Good hatch with decent wrap around wing, wing was painted 100$
85-92 base/formula tail lights good shape 40$
85-90 ground effects, door and quarter decent shape 50$ for all
Good 85-90 trans am/gta rear bumper with "Pontiac" logo. 50$
Patch panels, floors crossmembers Ask
Tube steering column, bolts in, with custom hanging gas and brake pedals, grant quick connect wheel with momentary push button. 200$
Manual rack and tubular crossmember, needs to be welded in or fabbed to bolt in place of sway bar, 100$
Sparco evo2 seat and 5pt harness, very nice shape, expired sfi. 200$
Gas door 5$
Bmr Trac pack style full adjustable torque arm, weld in crossmember style. 150$
I'll cut the roof off the car and remove the cage if somebody wants to try and use it somehow. Pm me
Th400 chromoly driveshaft, 1350joints with yoke 43.5 c to c. 250$
Th400 trans crossmember, no TA mount. 25$
Aerospace lightweight front brake kit with spindles. 500$
Racecraft chromoly k member and coilover a arms, clean and ready to go. 500$
Rod ended LCA and panhard bars, probably chromoly. 150$
Hunterdon count
-Phil
Gas door 5$
Hunterdon count
-Phil
It's sold , I didn't remove the pic
The newest 3rd gen is 26 years old, so yeah, any original parts will most likely be showing their age
1 Post
Car: 1989 Camaro RS
Engine: 383
Transmission: TH400
Axle/Gears: 9 inch, 35 spline drag spool,4.56
Gas door 5$
Hunterdon count
-Phil
Gas door 5$
Hunterdon count
-Phil
Yes the brakes are available
Ttt
#43
#45
No it's gone, was for a th400 anyway
#46
1 Post
Car: 92 Camaro Z
Transmission: Built TH350 with 3200 stall
Axle/Gears: 4th gen, 4.10
Hello, do you still have the adjustable torque arm and driveshaft loop? If you do how much are you asking for it?
Pat
Pat
#47
Are the back quarters rust free? I need both lower rear sections, and the rear passenger side rocker arm mounting are sheet metal.
IF the passenger side rocker box (the frame) ill take that too if its not rusted.
<- restoring my high school car...
#48
I think the driverside is good, the passenger side kissed a wall and has rotting in the spare tire well.
#50
