I bought a LS1 set up and decided my 305 TPI no longer needs to take up space. I had it running nice before I took it out. Let me know if there is anything you need off of it. Injectors were from Southbay, New EGR system with a modified EGR solenoid. Engine wire harness and 305 TPI 5 speed ECU. 5 Speed is gone, flywheel and clutch still in engine. Also have the air intake and MAF sensor.
Thank you everyone so far for your responses.. I have been moved to 12 hrs so my response is going to be a little slow. I am parting it out. I am planning on tearing it down this weekend.
JC I will get you pictures of the EGR valve solonoid I used. It was recommended from an article I had read 3 years ago and it did work. I found all new parts. I will get a price for you.
Thank you brother. I appreciate it. Keep me posted and glws on the rest of the parts.
At this time all that is left is the following
Plastic distributor cover (no bolts)- $27 shipped
Throttle body with new TPS and new IAC- $75 shipped
ECM (new reman) with prom. $90 shipped
