I have a complete 1986 2.8 MPFI engine and trans sitting in my barn. Engine had somewhere between 140 and 150k miles. (odometer broke) I also have its wiring harness (cut up), ECM, guage cluster, radiator, cooling fan, catalytic, y-pipe, front struts, front coil springs and engine mounts.
A few of the parts are new: Ignition coil, MAF sensor, TPS, IAC, fuel pressure sensor, oil pressure sensor, distributor rotor and cap, spark plug wires, water pump and timing chain cover.
LaGrange, Texas.
Will post more pics if you ask for them.
