[CA] ZZ383/SP383 hydraulic roller cam
Old 10-07-2021, 07:12 PM
ULTM8Z's Avatar
Came with the HT383 short block I ordered. Never been run. I'm putting in a different cam.
https://www.summitracing.com/parts/nal-19210723
$300, not including shipping.
Old 10-08-2021, 10:20 AM
zman1969's Avatar
Car: 90 Formula 350
Axle/Gears: Dana 44 3.54
Re: ZZ383/SP383 hydraulic roller cam
Is this a ZZ383 cam or HT383?? the HT383s cams can be had cheap
Old 10-08-2021, 11:46 AM
ULTM8Z's Avatar
No it's definitely the ZZ383/SP383 cam, not the HT383.
HT383 is small... 196/206 @.050. ZZ383 is 222/230 @.050
Basically what happened was I ordered the GM crate 383 short block, which is common across the ZZ/SP/HT line of 383's that GM sells. The short block is actually advertised as no cam included (among other things like timing chain, oil pump, etc). But when I got the short block (dropped shipped from Scoggin Dickey, through Summit Racing), it came with all that stuff.
I contacted Scoggin Dickey who said what I received as correct in their view, and that the cam was p/n 19210723 (the ZZ383/SP383 cam) So I ended up with this cam that I don't need. The cam has some numbers on it, but not this GM p/n. It's billet steel, not cast iron core.
However, to validate what they were telling me, I used my degree wheel to validate the specs.
Old 10-11-2021, 05:43 PM
ULTM8Z's Avatar
Bump
Old 10-22-2021, 03:12 PM
ULTM8Z's Avatar
Bump... someone can make me an offer on it.
Old 10-28-2021, 07:17 PM
ULTM8Z's Avatar
Bump...
Intake Duration at 050 inch Lift:
222
Exhaust Duration at 050 inch Lift:
230
222 int./230 exh.
Intake Valve Lift with Factory Rocker Arm Ratio:
0.509 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio:
0.528 in.
0.509 int./0.528 exh.
Lobe Separation (degrees):
112
Old 11-07-2021, 07:09 AM
ULTM8Z's Avatar
Bump
Old 01-06-2022, 11:01 PM
86vette's Avatar
Car: 1986 corvette
Engine: miniram 406 zz9 trickflow
I may be interested...if its still available.. can you post the part numbers that is on it.
Old 01-07-2022, 10:04 AM
ULTM8Z's Avatar
[SOLD] Re: ZZ383/SP383 hydraulic roller cam
Sorry... should have updated this thread. I sold it a couple of months ago.
ziggy89
09-07-2016 08:12 AM
KILLemALL
04-29-2016 07:17 AM
Justin 87 GTA
06-30-2009 09:50 AM
gruveb
12-03-2002 01:06 PM
Mike '91 Z28
09-12-2000 07:47 AM
Quick Reply: [CA] ZZ383/SP383 hydraulic roller cam
