NEED ASAP
Old Sep 7, 2006 | 02:31 PM
kjvail1204's Avatar
NEED ASAP
Im looking for a stcok TC or a small stall, and i nalso need a FlexPlate for a 350.
Im hitting abit of a down time in money (army artical 15) so the cheeper the better i just need to get it off blocks and rolling again.
Old Sep 7, 2006 | 02:56 PM
pr0zac's Avatar
Car: 1991 z28
Engine: forged 385 with afr's
Transmission: built 700r4
Axle/Gears: 9" and 4.56
i got a used flexplate and converter out of an 94 t/a lt1.. should all fit. what year is your 350 and what size flexplate do you have. i think i still have a big 1 piece rms and a big 2 piece rms also. email me at pr0zac623@aol.com
Old Sep 7, 2006 | 03:07 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
i have a 153 tooth flexplate for a 2 piece rms i'd sell for $10 plus shipping. not sure if that'll help you or not.
Old Sep 7, 2006 | 05:25 PM
kjvail1204's Avatar
info
I have a 153 tooth im not sure if its one or two pice main seal. how do i find that out
engine is a 86-95 350 is all i can tellyou its a reman. so the numbers onteh block have been milled off, i didnt knwo that till after i put it in. what other info do you need
Old Sep 7, 2006 | 07:50 PM
xpndbl3's Avatar
Car: 1984 Z28
if the crank has a locating pin on the back where the flexplate would bolt to, then it's a one piece rear main seal. the flexplate would not physically bolt to it. Also a one piece rear main seal flexplate would have a balance weight on one of the sides of the flexplate whereas the 2 piece RMS wouldn't.
Old Sep 7, 2006 | 07:54 PM
izcain's Avatar
Car: 1983 Camaro Z28
Engine: 584
Transmission: TSI Glide
Axle/Gears: Quick performance 9 inch
I have a stock 700-R4 converter if your interested pm me.
Old Sep 8, 2006 | 08:30 PM
kjvail1204's Avatar
Up date
ok men I have already got a sweet deal on the Flex Plate, i listed i was lookng for stock but if someone has a stall that will fit my application (non stock) let me know info listed below
Im looking to eventually make this a 383 stroker
Old Sep 16, 2006 | 09:20 PM
kjvail1204's Avatar
Hey just to let you all know that i have gotten at TC, so im outta the market for both things. thanks again for all your help guys
92GTA
Apr 9, 2016 07:39 AM
86White_T/A305
Mar 6, 2016 01:48 PM
Brother Al
Oct 14, 2015 06:39 AM
92projectcamaro
Sep 24, 2015 08:09 AM
NastyEngines
Group Purchases
Sep 8, 2015 10:14 AM
