wanted 89 camaro wiring harness
Old Jan 21, 2007 | 08:06 AM
bbsr72's Avatar
Car: 91 formula
Engine: 350 tpi
Transmission: auto
Axle/Gears: poss
i need a wiring harness for my 89 iroc ,thanx for your time
Old Jan 21, 2007 | 09:43 AM
mksp89IROCZ's Avatar
Car: 86,86,89, all IROC-Zs
Engine: 305cccarb,3sumtin,305 tpi
Transmission: 700R4s
Axle/Gears: 2:73open,3:42posi,2:73posi
which harness? i have a dash harness from an 89 v8 car.
Old Jan 21, 2007 | 01:20 PM
bbsr72's Avatar
Car: 91 formula
Engine: 350 tpi
Transmission: auto
Axle/Gears: poss
well,i do have a v8 ,and i need all of it ,cuz, someone hacked mine everywhere.so anyway how much?
Old Jan 22, 2007 | 10:41 AM
FASTASSBIRD's Avatar
Car: DEPENDS ON WHAT DAY IT IS
Engine: 428 STROKED TO 462
Transmission: 6 SPEED
harness
i have a complete interior harness and headlight harness from a 91 z28 should be the same (but check on the forum and make sure $150 for everything that I have plus shipping give me a call if interested
559-213-2752
ERIC
AND THE TAIL LIGHT HARNESS AS WELL THE ONLY THING I DO NOT HAVE IS THE ENGINE HARNESS.
ERIC
Last edited by FASTASSBIRD; Jan 22, 2007 at 10:41 AM. Reason: Automerged Doublepost
Old Jan 22, 2007 | 08:08 PM
correct me but i know the 91 will have the air bag sensors which wasn't in the 89. i have read that the 89 was a one only year. can anyone support this?
Old Jan 23, 2007 | 10:13 AM
WIRE HARNESS
I THOUGHT THE AIR BAG STUFF WAS IT'S OWN DEDICATED HARNES, NOT SURE I HAVE THE ENTIRE SET-UP THOUGH COLUMUN STEERING WHEEL WITH THE AIRBAG EVEN THE 91 DASH GAUGES, AC CONTROLLER AND COMPUTER IF YOU WANT IT ALL SHOULD JUST BOLT IN WOULD BE A GREAT WAY TO UPGRADE ALL AT ONCE!
ERIC
Old Jan 24, 2007 | 10:08 AM
Thomas's Avatar
Car: 87' Pont GTA
Engine: 5.7L
The 89' TPI Wiring Harness is a one year only harness. It is a Mass Air Flow System without the Cold Start Provision and also having the VATS System which was the only year that this was used. Make sure you get the complete wiring harness for the whole car as that they do not come apart into sections like the earlier years. The 90' to 92' TPI is a Speed Density System which is totally different. Good Luck in your search!!
Thomas R. ***
(800) 460-6789
(818) 700-7970
www.houseofcamaro.com
Old Jan 24, 2007 | 10:51 AM
WIREHARNESS
SO THE ENGINE HARNESS IS DIFERENT, BUT THE INTERIOR AND LIGHTING HARNESS ARE THE SAME? I THINK THAT IS WHAT THOMAS IS SAYING. IF SO I DO NOT HAVE THE ENGINE HARNESS ANYWAY, BUT I HAVE EVERYTHING ELSE. LET ME KNOW IF YOU WANT IT
ERIC
559-213-2752
Old Jan 25, 2007 | 11:42 AM
Thomas's Avatar
Car: 87' Pont GTA
Engine: 5.7L
The Interior Harness is also different. The Speedometer is cable on the 89' and Electric on the 91' - 92'. The Dash is also completly different as is everthing else. Again the whole thing has to be from an 89' only with out many rewiring issues
Thomas R. ***
(800) 460-6789
(818) 700-7970
Old Jan 25, 2007 | 11:47 AM
DASH HARNESS
NOT TO BIG OF A DEAL, I HAVE THE COMPLETE DASH WITH INSTRUMENT CLUSTER AND EVERYTHING, I PULLED IT OUT AS ONE PIECE WHEN I PARTED THE CAR OUT CAUSE IT WAS IN ABSOLUTE PERFECT CONDITION HARNESS IS STILL INTERWOVEN IN THE BLACK PLASTIC DASH AC CONTROLLER STILL THERE GUAGES STILL THERE EVERYTHING. JUST THOUGHT IT MIGHT BE EASIER TO PULL OUT THE 89 AND DROP IN THE 91 SET UP
ERIC
Old Jan 25, 2007 | 06:00 PM
switching to the 90-92 dash also has different mounting brackets at each side of the dash. i think those would have to be welded in also.
Old Jan 25, 2007 | 06:07 PM
DASH
SEEMS TO ME THAT THE DASH BOLTED IN ALL THE SAME PLACES AS MY GTA WHICH IS AN 88 THE DASH IS SUPER CHERRY,SO MUCH THAT I ACTUALLY CONTIMPLATED PUTTING IT IN CAUSE I AM NOT A BIG FAN OF THE DIGITAL GAUGES OR THE ROUND ONES. SO MUCH HEADACHE OVER THE DASH AND NOBODY SEEMS TO WANT IT SO MAYBE I WILL TRY IT ANYWAY
ERIC
Old Feb 9, 2007 | 01:40 AM
bbsr72's Avatar
Car: 91 formula
Engine: 350 tpi
Transmission: auto
Axle/Gears: poss
my car is tbi,but does the wiring harness still have to come from an 89?i'm wondering bcuz my ign. key has some kinda chip or something in it. i think someone called it a vat?
Old Feb 9, 2007 | 04:16 AM
ted gerlach's Avatar
Car: 89 formula convert looks like a 92
Engine: original 350 tpi engine
Transmission: auto
Axle/Gears: 373 10 bolt with LS1 brakes
is your car a stick or auto?? this weekend i will have an 89 iroc for parts
Old Feb 9, 2007 | 04:41 AM
bbsr72's Avatar
Car: 91 formula
Engine: 350 tpi
Transmission: auto
Axle/Gears: poss
mine is an automatic.thanks for replying.
Old Feb 9, 2007 | 08:55 AM
Thomas's Avatar
Car: 87' Pont GTA
Engine: 5.7L
Yes, you will need to change the Dash Harness and use your old Pass Key Module (which unplugs from your old harness) it is matched to the key of your steering column. Good Luck!
Thank you,
Thomas
(800) 460-6789
(818) 700-7970
Old Feb 10, 2007 | 01:43 AM
Transmission: auto
my iroc is a stick car,
midge54
Sep 2, 2020 07:13 PM
midge54
Dec 27, 2019 04:14 PM
crt454
Interior Parts Wanted
Jun 23, 2017 02:25 PM
Ikes 91Z
Dec 9, 2015 03:49 PM
Reddeath210
Oct 6, 2015 08:20 AM
