Looking for proformance cam...
Old Mar 18, 2007 | 12:39 AM
My91Rox's Avatar
Car: 91 Camaro z28
Engine: TPI 350
Axle/Gears: 3.23 open
I have a 91 z28 with a 350 TPI... Im looking for a proformance camshaft. If anyone can help me out please contact me!
Old Mar 18, 2007 | 06:50 AM
86camaro383's Avatar
Car: 86 Iroc
Engine: 383
Transmission: TH350
Axle/Gears: 3:73s!
I have a crane energizer cam. 266H grind, flat tappet.
30 buck shipped
Old Mar 18, 2007 | 06:55 AM
My91Rox's Avatar
Car: 91 Camaro z28
Engine: TPI 350
What is the lift and RPM range with that cam?
Old Mar 18, 2007 | 11:19 AM
Car: 86 Iroc
Engine: 383
Transmission: TH350
Axle/Gears: 3:73s!
The lift on the intake/exhaust is a .440
The duration is 266*
I dont remember the RPM range, but i think it was 1600 to 5500
I dont have the lifters, its just the camshaft.
Old Mar 18, 2007 | 11:29 AM
vincode8's Avatar
Car: 84 Z28
Engine: L69HO
Axle/Gears: 3:73
91 350 is a Roller motor, so you need a Roller Cam....Flat tappet won't work, FYI. Best bet would be to get a ZZ4 Cam off ebay, they are cheap, like $125 bucks NEW takeouts.
Old Mar 18, 2007 | 07:10 PM
My91Rox's Avatar
Car: 91 Camaro z28
Engine: TPI 350
thanks
thanks for the heads up
Old Mar 19, 2007 | 08:07 AM
slow83sc's Avatar
Car: 83 camaro sport coupe/ 1981 Camaro
Engine: 2.8 2bbl
Transmission: thm200c
If you are running bone stock heads you can't run a zz4 cam, you will need different valve springs, and may also need long slot zz4 rockers.
Old Mar 23, 2007 | 07:56 PM
gmoney1082's Avatar
Car: 1989 GTA
Re: Looking for proformance cam...
pm'd you
thekurlyone
Sep 30, 2015 12:54 PM
Dialed_In
Aug 20, 2015 01:45 PM
burnoutrpm
Aftermarket Product Review
Mar 22, 2001 04:23 PM
burnoutrpm
Feb 18, 2001 02:24 AM
