looking for a 350 in nj
Car: 1983 camaro Z28
Engine: 383 stroker
Axle/Gears: 4:10 full disk posi
<TABLE id=HB_Mail_Container height="100%" cellSpacing=0 cellPadding=0 width="100%" border=0 UNSELECTABLE="on"><TBODY><TR height="100%" UNSELECTABLE="on" width="100%"><TD id=HB_Focus_Element vAlign=top width="100%" background="" height=250 UNSELECTABLE="off"> my 305 just isnt cutting it haha. i need the extra kick, so im looking for a 350 or one that is storked to 383. i'll be putting a 142 supercharger on it. i live in washington nj. thanks!
</TD></TR><TR UNSELECTABLE="on" hb_tag="1"><TD style="FONT-SIZE: 1pt" height=1 UNSELECTABLE="on">
</TD></TR></TBODY></TABLE>
Car: 86 Iroc
Engine: 383
Transmission: TH350
Axle/Gears: 3:73s!
Re: looking for a 350 in nj
I have a l98 shortblock+cam and lifters. It has 2 burned pistons, needs to be rebuild in lower NY zip 12566. 150 and its yours...
Car: 2000 BMW M5
email tomofalltrades6@aol.com. He is located in Tom's river, NJ. He is a great guy and his livelihood seems to be the never ending stream of 3rd gens that he is always parting. He usually has roller 305/350s kicking around.
Engine: 383 stroker
I'm selling a 350ci hyd roller motor, motor was freshened up, has a stock crank, rods and Hyperu pistons, fully ported cast iron heads, 64cc chambers, 9.8:1 compression, custom comp cams hyd roller cam (nitrous grind) 218/230 dur @ 0.050 w/ a 114 ls, and a converted LT1 intake. Motor comes with a balancer, oil pan, flex plate to intake, you need a TB, fuel rail, injectors, distrib and accessories.
$1000 will seperate and sell without the intake.
Motor was all ready to go in a project car as you can see in the pic, but just have no time to finish it up. Motor will make 385hp and in a camaro/firebird with average bolt-ons and a proper tune, should go mid to low 12's.
I ran this cam in my '90 camaro, 355ci with modified cast iron LT1 heads and modifed LT1 intake, stock weight, 3.73 gears, th400 trans went 11.8's on motor and high 9's on nitrous.
Tony
Krazedz@yahoo.com
Located in NJ 08721
Tony
Krazedz@yahoo.com
Located in NJ 08721
Car: 86 Iroc
Engine: 383
Transmission: TH350
Axle/Gears: 3:73s!
dont have pics but I could get them
its a stock cam, everything is all stock. It has 88K on it, it ran into detenotion with bad gas...
Car: 86 Iroc
Engine: 383
Transmission: TH350
Axle/Gears: 3:73s!
no actally. Beleve it or not, I was going to rebuild it for the guy, and just ball hone it. It doesnt even have a ridge or anything. I was just going to replace the rings/bearings and pistons and send it on its way.
Car: way too many
Engine: 283s to 454s
Transmission: autos and sticks
I have a complete 1989 350 from an 89 Z71 silverado, TBI fuel injection still has the TBI and wiring harness, serpentine belt system, compelte fan to flexplate air cleaner to pan. Engine ran fine and does not need a rebuild. $400 in NY zip 12538.
FormulasOnly
Sep 10, 2015 09:07 PM
