Anyone Know Where I Can Get a Cheap Posi???
Old Feb 25, 2008 | 06:23 PM
sbcfirebird's Avatar
Want a title? Post!
Car: 1983 Pontiac Firebird
Engine: 400 small block chevy
Transmission: TH-400
Axle/Gears: 3.73 gears
I have an 83 firebird and i need a posi or a limited slip and cash is tight. Can anyone help me find a cheap new or used (in good shape) posi or limited slip? Thanks
Old Feb 25, 2008 | 06:39 PM
ccook-92-305's Avatar
Car: 1992 Camaro RS
Engine: 305 TBI
Transmission: 700R4 w/transgo 700 shift kit
Axle/Gears: 3.42 posi
Re: Anyone Know Where I Can Get a Cheap Posi???
I got a rebuilt GM govloc off ebay for my 28 spline $185.00. You'll need a 26 spline (i think) and cheap definately equals ebay. I have had lots of bad experiences with ebay tho. My posi worked out but my brother bought one for his truck and it was junk. Look for lots of pictures and good feedback and good luck! Search (7.5 26 spline posi)
just curious... hows that 400 run? im buildin a 406 for my '92. just wonderin.
Old Feb 25, 2008 | 07:05 PM
Want a title? Post!
well i have only run it 2 times because i got my licence taken away but i raced a 2001 mustang gt with completely blown header gaskets and still beat him from 0-120 so it's runnin pretty good but i really want that posi to set it off right. im gunna be boring it out to a 406 eventually but money is tight at the moment...thanks for the reply.
Old Feb 25, 2008 | 07:46 PM
Car: 1992 Camaro RS
Engine: 305 TBI
no problem... somethin you might want 2 think about, and i know money is tight but with that 400 its not sayin too much to say you might blow that 7.5 up real royally. a gm 12 bolt or a ford 9" might really be somtin to save for. It wouldnt be as bad if it was the 7.625 like mine with the 28 spline axles but those 26 spline 7.5's are pretty wimpy.
just somtin to think about, maybe you dont want to spend money on anything for the 7.5 if its gonna get torn up. you'll be money ahead to do it right the first time. just my
Old Feb 25, 2008 | 10:01 PM
Want a title? Post!
thanks for the imput. will a ford 9" really fit in the firebird? do u suggest richmond or something else?
Old Feb 25, 2008 | 11:37 PM
wesilva's Avatar
Car: 1966 El Camino Custom
Transmission: 200R4
Axle/Gears: 3:73 12 bolt with Brute Strength
PM sent....
Old Feb 26, 2008 | 04:26 PM
Car: 1992 Camaro RS
Engine: 305 TBI
yea a ford 9" will fit however i think you have to get a special one that has a place to hook up your torque arm. im not sure if you can order them from richmond (which would probably be the best... and most expensive) or somewhere like moser engineering. it would be something to look into. if not i think you can somehow convert to a 4 link or somtin but thattl probably run u a pretty good chunk of change.
Old Feb 26, 2008 | 09:18 PM
Tiresmokin's Avatar
I have a 9", Currie axle, made for the F-body.
Old Feb 27, 2008 | 03:15 PM
djtricia's Avatar
Car: 1986 Z-28
How about a stock 2:73 posi rearend? Located 49002
Old Mar 1, 2008 | 04:06 PM
87cmroiroc305ho's Avatar
Car: 1987 chevy camaro iroc-z28 305 h.o.
Engine: 305 high output
i got it, with the ring and pinion, not the whole rear end tho, selling cheap, email me at nything4ubabe@aim.com
Old Mar 6, 2008 | 10:01 PM
Want a title? Post!
sounds good...what gears are they?
Old Mar 21, 2008 | 05:29 AM
zepp777's Avatar
Car: 1988 camaro Rs (z-28 clone)
Engine: 305 tbi (building 383 stroker(
Axle/Gears: 3.73 and a ratchet locker
hey you can always get a locker its like a posi but normaly cheaper sence if u take a corner slow it makes noise unlocking but its full posi all the time till you go do a corner then it lets one wheel spin slower
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
Damon
Sep 26, 2015 04:29 PM
