PORTED TPI SETUP - runners, plenum, and baseplate
Old Feb 7, 2009 | 12:10 PM
Stangski09's Avatar
Car: 1988 Pontiac Trans Am GTA.
Engine: 385 stroker sbc
Transmission: TKO600
Axle/Gears: Moser 9" 3.70 Wavetrac
So guys I'm looking for a ported plenum, runners, and matching base plate. I do not care about brands here.
Post and tell me what you have.
Old Feb 17, 2009 | 08:11 PM
Duts87ss's Avatar
Car: 1987 Monte Carlo SS
Engine: HSR 383 AFR180/268XFI EBL
Transmission: 200-4R, Edge 2800 L/U
Axle/Gears: 7.5/3.73/PowerTrax No-Slip
Re: PORTED TPI SETUP - runners, plenum, and baseplate
I've got a slightly ported Eddy base, Corvetteplenums.com ported SLP runners, and a self ported plenum. The runner are CSI and the plenum is not; so, you'll have to remember not to cut out the opening for it when making your gaskets. I'll take $700 shipped for the whole set (in the US).
Some pics at www.photodump.com/duts87ss
Old Feb 17, 2009 | 10:08 PM
Stangski09's Avatar
Is the edelbrock base part number 3860? And is the plenum and runners for 85-88?
what does "csi" mean?
Old Feb 17, 2009 | 11:35 PM
Toyota h8r's Avatar
Car: 1987 Z28
Engine: LG4
Cold Start Injector
Old Feb 18, 2009 | 03:56 AM
Duts87ss's Avatar
The Plenum is '89+. The runners are ; '85-'89. I don't remember if the base is 3860 or 3861; it is for both early and late style bolt patterns.
Old Feb 18, 2009 | 08:48 AM
Stangski09's Avatar
If you flip over the base and look on the back there should be a cast number. If it's 3860 I will definitely buy this off you. And please take a detailed picture of the base and the cast number and email them to spyoptic_9@hotmail.com. Thanks. I will give you $220 shipped to Edmonton, Alberta, Canada T5X-5Y4 17223-113ASt
Old Feb 18, 2009 | 04:56 PM
Duts87ss's Avatar
It's on the car now. I'm not going to pull it unless I sell it all. What's the difference b/w 3860 and 3861?
Old Feb 18, 2009 | 05:28 PM
Stangski09's Avatar
3861 is for pre 85 heads and after market heads. They have a different bolt angle. 3860 are the ones for my setup.
Old Feb 18, 2009 | 06:03 PM
Duts87ss's Avatar
Mine has slotted center holes for use with either.
Old Feb 18, 2009 | 07:22 PM
Stangski09's Avatar
So it must be the 3860 base then. That would be sweet if it was.
gta90
Sep 15, 2015 04:00 PM
masonta
Aug 31, 2015 10:14 PM
Dialed_In
Aug 20, 2015 01:45 PM
Sanjay
Aug 12, 2015 03:41 PM
squiggy2
Aug 9, 2015 09:30 PM
