350 TPI Prom
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Car: 1989 Red T-Top Firebird, 1989 Iroc
Engine: 2.8L 173 C.I., 355
Transmission: Th700r4 Auto, Built TH700R4
350 TPI Prom
I'm in need of a TPI Prom chip for a 350, and a set of 350 Injectors. I'm in the process of doing a 305-350 swap.
![lmao](https://www.thirdgen.org/forums/images/smilies/lmao.gif)
Car: 89 Iroc Convertible
Re: 350 TPI Prom
I have a couple 350 TPI Proms.One is from an 88 and the other from an 89.Asking 80 dollars each shipped
Re: 350 TPI Prom
Still looking for injectors and a good deal on a stock 350 prom for an 89.
Car: 1987 Yellow IROC
Transmission: A4
Re: 350 TPI Prom
I should have a TPI 350 computer out of a 91 Z28 $60.00 shipped in the lower 48
coke_and_stuff@yahoo.com email me if interested
Joey
Joey
Re: 350 TPI Prom
Joey
Joey
Transmission: A4
Re: 350 TPI Prom
It should work but you need to do some homework just to make sure. Its all or nothing as its worthless without it.
Joey
Joey
1 Post
Car: 91 Formula
Engine: 350 L98 SD TPI
Axle/Gears: 10 bolt PBR 3:23 disc posi
Re: 350 TPI Prom
90-92 TPI Proms and ECMs (ECU or computer) will NOT work on a stock 89 or older TPI setup.
Are you installing a 89 TPI? If not what year is your TPI setup?
Re: 350 TPI Prom
The TPI Setup is out of an 89, and going back into the 89. So I need an 89 and older prom/ecm?
1 Post
Car: 91 Formula
Re: 350 TPI Prom
89 f-body TPIs are a 1 year only setup. You need a 89 only prom and a 1227165 ecm.
I have a remanufactured 1227165 ecm and a 89 350 TPI prom from a 89 GTA 350 TPI.
Make sure you get a engine wiring harness from a 89 305 or 350 TPI Firebird also. The harness in a Camaro is different due to battery location.
1 Post
Car: 91 Formula
Re: 350 TPI Prom
Here is a helpful link for prom and ecm numbers and codes.
http://www.3rdgenformula.com/89/promcodes.htm
The prom I have is APYU 3516.
1 Post
Car: 91 Formula
Re: 350 TPI Prom
Here is what I have. I do have the cover and the 2 screws for it, I just took it off for the picture.
Re: 350 TPI Prom
This is going into my iroc. It is an 89, with a 305 tpi originally. So the is that ecm acceptable still? Or do I really need the whole new ecm? Are you offering to sell the one you have? haha, I couldn't quite tell.
Re: 350 TPI Prom
Looks like the ECM number is the same between the 305 and 350 for 1989?
1 Post
Car: 91 Formula
Re: 350 TPI Prom
Your ECM will work it is a 1227165 you just need to change your prom or have your 305 prom burned for a 350.
I would suggest Ford injectors also. Stay away from the Multec injectors.
Yes its for sale.
$85 shipped for the prom only.
I thought you were putting the 350 TPI in your 89 Firebird 2.8
Yes its for sale.
Car: 89 Firebird Formula
Engine: 305 Vortec, Single-plane, 4 barrel
Transmission: T5, soon 700R4
Axle/Gears: 88 10 Bolt, Disc, Auburn, 3.23
Re: 350 TPI Prom
I have a TPI 350/Auto Prom in my 165 computer in my 89 Formula. Let me check what the chip's code is and make sure it's 89 but, it would probably suit your needs quite well. Though it has not suited my needs as I have an 89 305TPI 5 Speed, lol.
Re: 350 TPI Prom
Hey that could be great! let me know the number and how much you want for it!
1 Post
Car: 1990
Axle/Gears: stock
Re: 350 TPI Prom
did the car you had with the 305 have tpi or tbi. if it was tbi you will need to replace the wiring harness in front of the firewall and behind it. so get every wire you can find and dont cut anything.
1 Post
Car: 1990
Axle/Gears: stock
Re: 350 TPI Prom
Re: 350 TPI Prom
305 was TPI also, so its the same. Thanks for checking! :-)
1 Post
Car: 1990
Axle/Gears: stock
Re: 350 TPI Prom
you are one lucky man - i have to pull every wire with my 305 tbi and put the tpi stuff in but i dont want to do that until i get the heads.
be sure to keep everyone posted with how the swap goes.
good luck.
good luck.
Re: 350 TPI Prom
Hmm, well i am sorry that I gave you false hope - It turns out that the one I have is an APYR, which is listed on several sites as:
APYR 3506 3501 Auto 2.73/2.77 Fed F
Though the interesting thing is that I have an OTC Monitor 2000 and when hooked up across the ALDL connector it reads it as a 350/Auto Chip. Sorry man.
Re: 350 TPI Prom
here is another site with the prom numbers that my82roc sent me, I think its a little less confusing than the other one!
http://chevythunder.com/prom_bcc_1989.htm
Re: 350 TPI Prom
Re: 350 TPI Prom
yeah, i have a saved copy of that page on my computer. Hey, if you run out of luck i might be able to burn you a prom - a stock image of one that is. I couldn't find the chip i needed so I bought a Willem programmer. I ended up burning a APYS the other day for my car on a EPROM that can be erased/rewritten electrically.
I think I spent $15-$30 on the programmer (I bought it last year, never got around to using it till now) and a used "flash" chip for like $7 (lol, it says "ALTEREDIMPORTS" on it, haha). I'm gonna be plugging it in in a couple days, wish me luck.
Like I said, I could burn you a chip, but you would have to install it into an existing MEMCAL (err, I don't think it's actually a MEM-CAL on a 165?). But, be warned - I'm not trying to sell you the service - the chips are like $7 on ebay shipped, then I would just burn it and ship it to you. What you do from there is up to you.
I know how it is to have the wrong chip! I feel your pain!
1 Post
Car: 91 Formula
Re: 350 TPI Prom
Today you still can't find one????????????
Re: 350 TPI Prom
I PMed you back last Thursday saying the deal fell through. And I asked if you still had it, and if you did if $100 + shipping firm would do it, and if you accepted paypal. A week later with no response made me assume you no longer had it/you weren't accepting my offer.
1 Post
Car: 91 Formula
Re: 350 TPI Prom
In your return responce you said you were going a different direction or something and didn't need it.
I NEVER said $100 firm plus shipping!!!
Re: 350 TPI Prom
The last time we wrote each other was a couple of weeks ago. I wrote you and asked if you found out the info on the ECM you were looking for and that was after you left me hanging for over a week.
1 Post
Car: 91 Formula
Re: 350 TPI Prom
I don't have anything like that from you on 6/4/09.
I'm asking for $85 plus shipping for the prom and if you would have offered me $100 shipped for the prom I would have takin it. Thats more than what I was asking.
Did you offer $100 shipped for the ECM and prom?
Re: 350 TPI Prom
I need to get the car going because i need to get rid of it.
Re: 350 TPI Prom
I will buy the prom and the ecm if that is how you want to sell it. I just need it asap because I NEED to get this thing on the road.
1 Post
Car: 91 Formula
Re: 350 TPI Prom
I talked to the other member on the phone a few minutes ago and he is going to buy the prom from me but he might buy the ECM also if he can cancel the reman. ECM his mechanic ordered.
If things change tomorrow when he calls me and doesn't need it, I will let you know. Right now the ECM and prom are his.
#45
Re: 350 TPI Prom
I have a ECM out of a 89 firebird. it is a 165 ECM with a AUJM prom. Replaced it with a EBLflash. Was working when pulled. Also have a set of pink top ford injectors that were also on the same car but due to upgrades were too small. If interested get in touch with me....
#47
Car: '91 Camaro RS
Engine: 355 TPI, Comp 268xfi, bowtie heads
Re: 350 TPI Prom
I am also in need of a 350 TPI memcal
I need one for 90-92, 1227730, AUJP
need it ASAP please
need it ASAP please
