[IL] need a idle air control motor
Old May 18, 2009 | 06:19 PM
teamstream's Avatar
Car: 91 Purple Z28
Engine: 5.7 TPI
Transmission: 700 R4
Im looking for a GOOD used idle air control motor for my 91Z. ever since i had my shop install a new acdelco idle air, it hasnt acted just right. it wants to idle up and down when i start, so i thought i'd try a different one first to see if thats my problem. looking to spend under $20..prefer to use paypal
Old May 20, 2009 | 11:29 PM
BANDITSBC's Avatar
Car: 90 gta
Engine: 5.slow turbo
Transmission: tremec tko
Re: need a idle air control motor
i got one, just bought one last week and does the same thing, my old one for $15 plus shipping.
BUT.....
my problem was carbon build up in the throttle body. i cleaned the crap out of mine and still had one piece causing my plates to stick and not close all the way. try cleaning your throttle body bores first then let me know,
Old May 21, 2009 | 07:23 AM
teamstream's Avatar
Car: 91 Purple Z28
Engine: 5.7 TPI
Hey, i'll try that and see what happens. i know the one that was in it was bad cause it wouldnt idle at all...just died. so maybe it is carbon buildup...i'll clean it up today.
Old May 21, 2009 | 08:00 PM
BANDITSBC's Avatar
Car: 90 gta
let me know if you need it
Old May 24, 2009 | 08:50 PM
teamstream's Avatar
Car: 91 Purple Z28
Engine: 5.7 TPI
Well Bandit...i think that fixed my problem. lot of carbon buildup in there. if it does start acting up again, i'll pm ya. thanks alot though!
Old May 24, 2009 | 11:10 PM
BANDITSBC's Avatar
Car: 90 gta
no problem. hope that's all you need
Old Jul 3, 2009 | 05:06 PM
teamstream's Avatar
Car: 91 Purple Z28
Engine: 5.7 TPI
hey bandit, still have that idle control sensor? my car is still running funny. also if i could get a hold of a good used tps sensor and maybe a map sensor if anyone has one?
Old Jul 4, 2009 | 12:13 AM
1986iroc350's Avatar
Car: 1986 Iroc z
Engine: 350 tpi
Just curious but why would u put a USED IAC or TPS sensor on ANYTHING? If its used ist not gonna perform as good as new. I wouldnt think. I could be wrong. Even if you bougt a NEW one most come with a lifetime warrenty.
Old Jul 4, 2009 | 12:27 AM
teamstream's Avatar
Car: 91 Purple Z28
Engine: 5.7 TPI
well i had a shop install a new iac motor a while back and ever since they did it, it idles kinda funny and it never did before. its got a acdelco in it to. thought id try a good used one and see what happens. dont really want to spend the money on a new one and realize it dont make a difference.
Old Jul 6, 2009 | 08:10 AM
all4u's Avatar
Car: Firechicken
Engine: 350 + 30 over, 400 crank
Transmission: autotragic, stalled
Axle/Gears: not a one tire fire, thank god!
I have a brand new IAC motor that I was going to install in my car when the idle sucked. Turned out to be the TPS. I still have the IAC. If you could get to Villa Park, $20 and it's yours. Let me know cause I also have another buyer. They are $45 brand new.
Old Jul 6, 2009 | 11:52 PM
teamstream's Avatar
Car: 91 Purple Z28
Engine: 5.7 TPI
what brand is it? i'd have to have u ship it...to far to drive..im in central illinois
Old Jul 7, 2009 | 07:43 AM
all4u's Avatar
Car: Firechicken
Gp sorenson. I travel alot, if you are on the way to one of my work destinations, I could drive it out to you. Let me check my planner and I'll let you know.
1992rs/ss
Jan 31, 2025 05:10 PM
eightsixseven
Dec 16, 2024 01:50 PM
specialized
Jun 18, 2022 09:26 AM
1992rs/ss
16
Jan 28, 2016 09:58 PM
