Looking for T-5 setup
Old Sep 1, 2010 | 12:07 PM
bellez77's Avatar
Car: 1989 Camaro RS
Engine: 2.8L
i am looking for V8 T-5 and flywheel clutch setup for a pre 86 SBC. I am located in Central NY. Let me know what you have got.
Old Sep 1, 2010 | 04:55 PM
my82roc's Avatar
Car: 89 Iroc Convertible
Re: Looking for T-5 setup
I have a T-5 from an 84 1/2 LG4 L69 Car.I only have the trans itself,nothing else.Located in Philadelphia Pa
Old Sep 3, 2010 | 06:18 AM
Dante93GTZ's Avatar
Car: 1992 Z28 Heritage Edition
Axle/Gears: 3.23:1
You'll probably have to piece together what you want. I did. I got the flywheel and trans from one place, then the T/A mount at the junkyard, then the clutch from somewhere else, then the.......... it goes on and on.
So far, this swap has run me about $500 just in parts.
Old Sep 3, 2010 | 07:36 AM
bellez77's Avatar
Car: 1989 Camaro RS
Engine: 2.8L
I figured as much but i thought it was worth a shot to see what people have, i really want to find a donor car around here that i could turn around and sell or drop a 350 and TH350 in and sell to a friend.
Philly is somewhat of a drive from here. But how much would you take for it?
Old Sep 3, 2010 | 08:08 AM
my82roc's Avatar
Id take 250 dollars for the trans
Old Sep 4, 2010 | 09:56 AM
Camfire's Avatar
I have a complete T-5 world class setup out of a 92 Firebird still in the car and driveable $900.00.Located in Clarence NY. Near buffalo 716-445-0259
Old Sep 6, 2010 | 10:01 AM
tkcaraudio's Avatar
Car: 65 Nova Wagon
Engine: 358
Transmission: 350 turbo
Axle/Gears: 410
I have a T5 set up
it was in a 91 camaro Rs 112k original miles less then 900 on rebuild
All New seals/syncros/solid input shafts ect (this alone was $950)
Shifter (Stock)
Stock Clutch/pressure plate with some life left
Flywheel for pre 86 motor(2 peice rear main seal)
Id take $850+Shipping
I am in Chillicothe Ohio 45601
I have all the stuff for swap except slave cylinder/fluid resivor/clutch fork(i might have this)
614 364 9995
Old Sep 8, 2010 | 09:36 PM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
I've got a couple stock clutch/flywheels. I'll check to see if they are for 2-pc RMS,............
Old Sep 8, 2010 | 09:54 PM
88gta3508's Avatar
Car: 00 SSEi / 94 C4
Engine: 231 / 383
Transmission: 4T65E / ZF 6sp
Axle/Gears: 2.93 / Dana 44 3:45
1989 Complete WC T5 new TOB, New Flywheel
5th gear Billet retainer, Pro 5.0 shifter,
new cylinder if you need pedals $750 Your in NY I'll Meet you
Old Sep 15, 2010 | 06:04 PM
mooch1's Avatar
Car: 1985 camaro Z/28
Engine: 305 V/8 4bbl carb
Transmission: T5 WC
Axle/Gears: 3-23 posi with 4 wheel discs
hi , i need a cluster gear for my T5 , it's a 1987 ..anyone have?,,even used...thanks.
Old Sep 25, 2010 | 02:38 AM
lillee64's Avatar
Car: 1990 Iroc Z
Transmission: t56
Axle/Gears: 4:10
i have a t5 world class, complete trans and hydrolics, no clutch or flywheel though. $400
Old Oct 1, 2010 | 07:31 PM
mos68x's Avatar
Car: 1991 Camaro RS/Z28
Engine: 357 Edelbrock Intake & Holley Carb
Transmission: WC T-5
Axle/Gears: whatever stock is
What do you have right now for your car? I have a T-5WC setup that I swapped in but now I want the 700-R4 back lol. The trans does need a rebuild but the slave cylinder, clutch master cylinder, and clutch setup are brand new. Everything would be up for trade for a complete 700-R4 setup.
loud91rs
Oct 5, 2015 10:05 PM
meeklay812
Oct 1, 2015 03:46 PM
dusterbd
Sep 29, 2015 08:40 AM
Badass355ciz28
Sep 28, 2015 08:31 PM
Eric-86sc
Sep 28, 2015 11:37 AM
