[MD] t56 for swap needed
Old Oct 13, 2010 | 09:02 PM
tjl IROC's Avatar
Car: too many
Engine: SBC
Transmission: AUTOs and a 5 speed :D
Axle/Gears: you name it
t56 for swap needed
Looking for a t56 for a swap into my 82 camaro.
if anyone has one or better yet a 4th gen part car let me know
Old Oct 13, 2010 | 09:49 PM
quickkris2006's Avatar
Car: 1991 camaro vert
Engine: ls1 soon
Transmission: t56 soon
Axle/Gears: moser 12bolt 4.10 soon!
Re: t56 for swap needed
my buddy picked up a t56 swap at gm nats this past year and decided to go another rt with his trans am. think he wants 400 for it its got everything from pedals to trans to the sheet metal trans tunnel
Old Oct 13, 2010 | 10:11 PM
tjl IROC's Avatar
Car: too many
Engine: SBC
pm me a phone number
I'd like to know more
Old Oct 14, 2010 | 01:44 PM
86speediroc's Avatar
Transmission: 94 t56
Axle/Gears: 3:42 10 bolt
how much do you wanna spend i have one in my car i may take out it's a 12 sec car and i've never had any problems has brand new flywheel and clutch less than 500 miles, custom cross member slave cylinder and hurst pro billet shifter make me an off er i move to europe in 3 weeks and need to sell stuff
Old Oct 14, 2010 | 01:54 PM
tjl IROC's Avatar
Car: too many
Engine: SBC
Where are you located?
looking to keep the cost low
a few hundred for the total swap
less than a grand hopefully
Old Oct 14, 2010 | 01:57 PM
i'm in southern hersy but your not gonna find one anywhere for under a grand just the clutch,flywheel shifter and crossmember was $1000 then add bell housing ,slave cylinder and pedals plus the unit cheapest your gonna find it is about 1800 i've converted alot of these for people if you wanaa go sheap get a t5 and kkeep it under 400 hp
Old Oct 14, 2010 | 02:31 PM
tjl IROC's Avatar
Car: too many
Engine: SBC
I'm looking for stock parts not planning on upgrading the clutch or flywheel unless it needs it.
I'm looking at just taking all my parts from a 4th gen.
just looking to do this
http://www.skulte.com/T56.html
if I spend a little more than a grand on the swap it will be ok
but if I spend more than $2k total, I would be better off buying a good running 4th gen with a newer engine and lower mileage and saying heck with the swap.
I have had friends do this swap cheaper but I just need to locate a donor car or transmission priced at market value. (ie not paying 2k for a used transmission)
if I want to spend that much I would buy a new zero mileage one from jegs
Old Oct 14, 2010 | 03:12 PM
yeah you should be able to find a trans only for 800-1000 but you need a clutch,slave cylinder,pedals flywheel crossmember and shifter and mine is all stock believe it or not have better luck w/a stock clutch rather than performance
clutch $219
flywheel $105
master cylinder $50
slave Cylinder $50
shifter $220
Crossmember $200
bell housing $150
$1100 plus a trans
pedals n???
its gonna cost you bout 2g's no matter what if you want it you can ahve my complete set up for 2g's right out the car or the whole car is for sale its a 12sec daily driver
Old Oct 14, 2010 | 04:13 PM
tjl IROC's Avatar
Car: too many
Engine: SBC
I know I can do the swap cheaper by finding a wreaked 4th gen part car.
Thanks anyway
if anyone else has any location of a donor or parts let me know thanks.
Anyone see a wreaked one in a salvage yard near western MD?
I'm looking for one with some miles left on it.
Old Oct 14, 2010 | 06:05 PM
good luck thats the best way thats what i did its the best way buy a wrecked car take what you need and then sell off all the leftover parts to make back as much $$ as you can
Old Oct 17, 2010 | 07:50 AM
86camaro383's Avatar
Car: 86 Iroc
Engine: 383
Transmission: TH350
Axle/Gears: 3:73s!
Thanks anyway
good luck on spending less the 1000 bucks. If your using an older style 2 peice rear main seal, your going to have to drop 375-400 just on the converson flywheel. Junkyards wont sell a t56 cheap, just because thats one of the most popular trans swaps, and they know it.
Heres a breakdown of mine:
ram clutch aluminim flywheel 400
spec stage 3 clutch 500
GM master and slave with braided line 160
transmission 600 - lasted me about 400 miles before it lost reverse, then dropped 1600 on a rockland gear unit.
I bought a spohn crossmember and torque arm, but sopposidly stock ones will work.
I got the pedals for 75, you can buy the electrical pigs tails off ebay way cheaper the GM, and they fit fine.
Old Nov 12, 2010 | 07:54 AM
cuisinartvette's Avatar
Car: 67 ******mobile
Engine: 385 Solid roller
Axle/Gears: 4.11
I have a decent T56 with bellhousing stock shifter stalk (no handle) lower boot and hydraulics. $850/ALL
GM no longer sells these geta good used one while you can.
Bellhousings go for 3-400 on Ebay I was shocked lol.
ANyway if youre interested shoot me a pm.
Plus GM discontinued them early last yr
Old Nov 12, 2010 | 08:58 AM
tjl IROC's Avatar
Car: too many
Engine: SBC
Ca. is to far for me to come and look at it.
But I'm sure someone closer will hope at it.
Thanks for the reply.
IROCZ1989
Jan 24, 2016 03:55 PM
reiderz iroc
Aug 13, 2015 04:57 PM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
hokis
Aug 9, 2015 03:57 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
