305 tpi Engine wiring harness
Old Mar 4, 2011 | 04:51 AM
voljim's Avatar
does anyone have a complete Engine wiring harness for a 305 tpi PLEASE HELP i need an original if possible not a painless but will prob take one if i can get it Thank you it is for an 87 engine sbc
Old Mar 4, 2011 | 06:06 AM
ted gerlach's Avatar
Car: 89 formula convert looks like a 92
Engine: original 350 tpi engine
Transmission: auto
Axle/Gears: 373 10 bolt with LS1 brakes
Re: 305 tpi Engine wiring harness
what year are you looking for?
Old Mar 4, 2011 | 10:19 AM
IROC-Z28_CAMARO's Avatar
Car: 1988 IROC-Z, 95 Z-28
Engine: 357, 350 LT1
Transmission: Built 700-R4, 6-Speed
Axle/Gears: 2.73 Peg Leg, 3.42 Posi
I have one from a 87 and 89
125 plus shipping for either. Both are complete and uncut.
Lmk
Josh
Old Mar 4, 2011 | 12:53 PM
voljim's Avatar
it is for an 82
Old Mar 4, 2011 | 12:55 PM
voljim's Avatar
do you know if all the connecters will work from what i undrestand they will
82 never came with a TPI. What year is the engine or TPI set-up from?
Old Mar 4, 2011 | 12:56 PM
87 has provision for the cold start injector the 89 does not
Old Mar 4, 2011 | 01:07 PM
voljim's Avatar
the LU5 tpi was optional in 82 with crossfire injection
Old Mar 4, 2011 | 01:09 PM
roly50's Avatar
Want a title? Post!
hey dose nyone no wat could be the problem i have an iroc 5.7 tbi and wen i come to red light it somtimes stops like shuts off i strt it up again in im all good but i hate wen it stops nyone has a clue?
Old Mar 4, 2011 | 05:25 PM
Crossfire is not a TPI.
Old Mar 5, 2011 | 04:37 AM
voljim's Avatar
i am just now getting started after work i will get a good chance to all the details i need. i do know after looking today it is the SBC tpi with the corvette intake if that helps thank you for helping me with this i really appreciate it i misread the info on the website about the crossfire
Old Mar 5, 2011 | 04:41 AM
Transmission: auto
all depends on what year the tpi set-up is, with or without cold start injector,
Old Mar 5, 2011 | 08:03 AM
Just like stated depends on the year the TPI intake is off. More then likely it is a camaro or firebird set-up as the corvette system is laid out a little differently. I have both style harnesses when you figure out what one you need.
Old Mar 6, 2011 | 01:28 AM
voljim's Avatar
i don't have a pic but if you look on ebay under 305 tpi wiring harness there's one on there with the same intake as mine it is the only harness on there with the intake attached thank you again i still am gonna look at it tomorrow and find out exact specs
Old Mar 6, 2011 | 05:34 PM
Davids87IROCZ's Avatar
Car: 87 IROCZ
Engine: 5.7
Transmission: 700R
On my sons 87 TPI the PO did alot of work to the wiring. At the MAF, MAF relays, oil pressure sending unit, and other places they cut the original wire back a few inches from the connector and spliced in a new wire. The three relays at the firewall are just laying there. I wonder why someone would do this?
Old Apr 16, 2011 | 09:05 AM
maustin433's Avatar
Want a title? Post!
Car: Rockcrawler
Engine: 350 tpi painless wiring lunati cam
Transmission: sm465
Axle/Gears: Rockwells
If you need a stock wiring harness for a 87 tpi I have one. I will take 75 plus UPS shipping. I may have a painless harness in a few days. I am goin to propane instead of my TPI.
crt454
Interior Parts Wanted
Jun 23, 2017 02:25 PM
Reddeath210
Oct 6, 2015 08:20 AM
Brcharrelson
Aug 26, 2015 07:47 PM
jharrison5
Aug 19, 2015 05:53 PM
st.evel07
Aug 13, 2015 06:15 PM
