Need a mini starter
Old Feb 22, 2012 | 11:34 PM
Killerz187's Avatar
Car: '91 Camaro RS T-Top
Engine: 383 Stroker
Transmission: Bulldog 700r-4
Need a mini starter
As the title says, I needs me a mini starter. No brand preference. Small block 153/168 tooth.
Post what ya got.
Also looking for an adjustable Proportioning valve if anyones got one.
Old Feb 23, 2012 | 07:41 AM
rrf321's Avatar
Car: 91 formula
Engine: 5.7 not o.e.
Axle/Gears: 273 2 wheel drive
Re: Need a mini starter
https://www.thirdgen.org/forums/engi...t=mini+starter
Old Feb 23, 2012 | 10:05 AM
redneckjoe's Avatar
Car: 87 iroc-z
Engine: 454
Transmission: th350
i think an lt1 starter will bolt up if its 153 tooth. they used a smaller mini-type starter. might save some $ ?
Old Feb 23, 2012 | 11:04 AM
Dokken10's Avatar
Car: 91 Formula
Engine: 350 L98 SD TPI
Axle/Gears: 10 bolt PBR 3:23 disc posi
That's my starter. It was bought from Murray's speed and custom in Pompano beach, Fl. 954-788-6843
I just got off the phone with them. This starter is made by Nippon Denso and CHM puts their name on it or just the box. It fits our cars and others. Call them to verify. Thx
Old Feb 24, 2012 | 10:24 AM
Dokken10's Avatar
Car: 91 Formula
New info from Murray's on this starter.
Chevy 153 & 168 tooth flywheel
4:1 gear reduction
1.9KW
240 ft.lbs. cranking power
Old Feb 24, 2012 | 07:20 PM
Killerz187's Avatar
Engine: 383 Stroker
Just found out that I can't use your starter
My block doesn't have the 3 holes, just the two staggered.
Old Feb 24, 2012 | 07:35 PM
Dokken10's Avatar
Car: 91 Formula
I did a little research and I see what you meant. My bad.
Do you have a truck block?
Old Feb 24, 2012 | 09:51 PM
Killerz187's Avatar
Engine: 383 Stroker
Most likely, it's an early style block, dated to probably around 71 or 72.
Old Feb 27, 2012 | 06:52 AM
frankmurphy's Avatar
Ive got a csr starter with the adapter plate for a staggard bolt pattern part number 100PSBP. im located in bayonne nj its only got about 40 starts on it ill take 200 for it. Text or call at 2014639402 if interested.
3rd gen money
Oct 11, 2019 09:57 PM
Gunner242
Dec 25, 2015 04:49 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
Jlanz55
Sep 29, 2015 08:55 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
