Want to Buy: 5 speed firebird center console shift plate
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
Edit: Only need what is in this 1st post.
Did a T56 swap in my Formy and I need a 5 speed shifter plate.
If I need anything else I will post it up here.
Shoot me a PM with what you have!
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
Re: Want to Buy: 5 speed transmission mount and 5 speed center console shift plate
Doing a T56 swap in my Formy and need a few parts.
I need a T5 tranny mount (metal pieces that the torque arm mount goes in), a center console 5 speed shift plate for a firebird with just 2 window switches, and I need the lower shift boot (rubber)
Also, if someone is parting out cars or something, I am also looking for a manual trunk latch mechanism, trying to get rid of my electric pos pull down setup.
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
T5 stuff works just fine.
Car: 1992 z28, 2004 F250 6.0
Engine: Ls1
Transmission: m6
I have a 5 speed shift plate, PM me if you still need one.
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
Bump. Still looking. I need this stuff for my firebird.
Car: 85 Trans Am
Engine: 350: cam, aluminum heads, etc
Transmission: WC 5 speed
Axle/Gears: Dana 44, 373
I have a T5 shifter plate in great shape. PM me your info and I'll email or text over a few pics.
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
Still looking for everything in the OP... bump
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
Still looking... I get back to Cali on monday and need this stuff asap! Thanks for looking!
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
Nobody has anything? Wow
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
Bump... Going on leave in Feb. Looking to have the parts by then...
Car: 1985 Trans Am T-Top
Transmission: T-5 5 Speed
Axle/Gears: 3.42 posi 1LE 10 bolt
Re: Want to Buy: 5 speed firebird center console shift plate and Manual Trunk Latch
I have a manual trunk latch and the bracket for it too.
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
Off a firebird? If so, PM me a price shipped to 95973.
Want a title? Post!
Car: 1994 Jeep YJ
Engine: 350 TBI
Axle/Gears: ford 8.8 with 4.10
Still want shift Plate for T5? I have one from an 84 TA. PM me an offer and and we go from there.
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
Sorry, needs to be 85-92...
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
Bump... I need one with just the window switches. I don't have automatic side view mirrors.
Car: 1995 Formula
Engine: LT1 350
Transmission: Built 4L60e
Axle/Gears: 10 bolt, Eaton posi, 3.73's
I made a custom aluminum shifter plate for when I was going to swap to a manual tranny. I sold my car but still have the shifter plate.
I'll post a pic. It's much better than those darn plastic shifter plates that always crack at the corners.
I want $50 shipped for it, unless you want me to polish it for you, then it would be $75.00 shipped.
I can even powder coat it for you a metallic steel gray color, if you want, for $75.00 shipped.
The plate fits perfectly right into the center console, and you can have a shift boot company make a custom boot that will fit the plate.
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
That isn't a 85-92 Firebird console plate. Still looking!
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
No.
To seize all confusion... I need an 85-92 FIREBIRD 5 speed shift plate setup with window switches only.
1992 Trans Am
May 10, 2023 07:19 PM
colton_carlson
Mar 8, 2019 12:21 PM
