[PA] 350 TPI
Old Jun 13, 2013 | 08:29 AM
shred5150's Avatar
Car: 1988 Firebird Formula
Axle/Gears: 3.42 Posi
350 TPI
Looking for a TPI 350 to rebuild and swap in place of my 305 TPI. If its still in the car running that would be great if not thats ok as well. Not looking for complete junk, need a good starting point for a 355/383 build/rebuild. Must be within driving distance so I can come pick it up. Let me know what you got. Thanks
Old Jun 13, 2013 | 03:16 PM
87Iroc5.0's Avatar
Car: 1990 GTA
Engine: 355
Axle/Gears: 3.90
Re: 350 TPI
I see your up north...too bad, I have an L98 with about 7000 miles on it..but I'm down south.
Old Jun 15, 2013 | 10:17 PM
david frederick's Avatar
Re: 350 TPI
85'and89' corvette Ohio 44017
Old Jun 21, 2013 | 07:50 AM
beths91camaro's Avatar
Car: 87 Iroc vert, t-top
Re: 350 TPI
I have one I pulled out of an 89 Firebird Formula- 90,000 original miles.
I live near Scranton, Pa.
Old Jun 21, 2013 | 08:38 AM
shred5150's Avatar
Re: 350 TPI
How recently did you pull it out? Did it run/ how well did it run when it was pulled? (rod knock etc. ) How much are you looking to get for it?
Old Jun 21, 2013 | 08:40 AM
shred5150's Avatar
Re: 350 TPI
Whats the mileage or is it unkown? Were they running when pulled out? Is it the complete setup with TPI intake etc. What are you looking to get for each of them?
Old Jun 21, 2013 | 09:10 AM
Re: 350 TPI
Pulled it out earlier this summer. Hubby has already pulled it apart- cylinder walls look good- he felt it could just be honed, re-ringed and put back together.
Never had it running due to not getting keys when we bought it- but it would turn over freely, and try to start. Car was in an minor accident, then parked for 8 years.
Make me what you feel is a fair offer for it.
I also have two other blocks that are 350's- non roller, that I know need to be bored .030 over, and then they can be rebuilt.
Where you at in PA?
Old Aug 14, 2013 | 08:03 PM
FIRECHICKEN's Avatar
Car: '89 Formula 350
Engine: 5.7L L98 TPI
Transmission: 700-R4 Automatic
Axle/Gears: 7.5 disc posi 3.23
Re: 350 TPI
I have an 88 Corvette L98 350 block Roller block 2 bolt mains. Stock block has never been rebuilt. Spins freely needs upper ridges knocked down and light hone probably was running when removed to install in a Blazer project that did not happen. Also available are a set of 113 Aluminum corvette heads and complete TPI unit with 22# injectors. Plus a Painless wiring harness and 350 MAF computer wit Hypertech chip if needed.
Block $300
Heads $400
TPI Unit $200
Painless Harness $250
Maf 165 computer with chip $125
Let me know. Im near Harrisburg
Old Aug 24, 2013 | 06:56 PM
revelz's Avatar
Car: 87 iroc 89 pearl white' black 06gto
Engine: 350 Procharged AFR, T76 383 miniram
Transmission: 700r4, 700r4, LS2 t56
Re: 350 TPI
Hello, I have an 87 L98 350 with stock bottom end, but the top end was redone 4 years ago and the setup has roughly 4000 miles. The Engine has P600 intercooled procharger kit, AFR aluminum heads, Comp Cam camshaft, Holley Stealth Ram, MSD 6A and MSD Billet distributor, Megasquirt engine management with plx wideband O2, SLP shorty headers, etc. The engine runs very strong. I wanna sell the engine complete, but I am willing to part it out. The engine is in a 87 camaro and still drives, so if interested you can take it for a test drive.
http://s237.photobucket.com/user/rev..._0375.mp4.html
bamaboy0323
Sep 3, 2015 06:07 AM
theurge
Aug 21, 2015 12:46 PM
Out-Cast
Aug 17, 2015 10:57 AM
Jlanz55
Aug 17, 2015 07:15 AM
bamaboy0323
Aug 15, 2015 07:20 AM
