[PA] L98 short or long block wanted
Old Jul 21, 2014 | 06:24 PM
greenyone's Avatar
Car: 91 G92 Z28
Axle/Gears: 342
Looking for a rebuild-able L98 roller block. Don't want to drive too far, so within and hour or two from Pittsburgh if you one available.
Old Jul 21, 2014 | 09:07 PM
jonarotz's Avatar
Car: 91 Z28
Re: L98 short or long block wanted
I have an 89 350 roller block, bored .030 and honed with torque plates, 2 bolt main. I'm just south of Cleveland. Let me know if you're interested.
Old Jul 21, 2014 | 09:14 PM
greenyone's Avatar
Car: 91 G92 Z28
Axle/Gears: 342
Just the block? Or does it have the rotating assembly (crank, cam, rods, pistons)
Old Jul 21, 2014 | 09:16 PM
jonarotz's Avatar
Car: 91 Z28
It's just the block
Old Jul 21, 2014 | 09:17 PM
greenyone's Avatar
Car: 91 G92 Z28
Axle/Gears: 342
Maybe. What are you looking to get out of it?
Old Jul 21, 2014 | 09:21 PM
jonarotz's Avatar
Car: 91 Z28
I don't know $100...I haven't shopped for one in a long time, sound fair?
Old Jul 21, 2014 | 09:22 PM
greenyone's Avatar
Car: 91 G92 Z28
Axle/Gears: 342
Has it ever had a rotating assembly in it since it was honed & bored?
Old Jul 21, 2014 | 09:27 PM
jonarotz's Avatar
Car: 91 Z28
Yeah, the reason I took it out was because I built a more capable bottom end for more boost and needed a 4 bolt block. It had low miles on it and the cylinders are in great shape.
Old Jul 21, 2014 | 09:29 PM
greenyone's Avatar
Car: 91 G92 Z28
Axle/Gears: 342
Think it would be ok with new internals or would you have it gone through again?
Old Jul 21, 2014 | 09:35 PM
jonarotz's Avatar
Car: 91 Z28
I was saving it for a "future" aka never gonna happen build because it's in great shape. I would run a flex hone down each bore just to give it a new crosshatch for your new rings and I would recommend a line hone of the mains. The only reason I say that is because when I did take it apart I noticed some weird bearing wear. If I remember correctly I think I even swapped the main bolts to studs.
Old Jul 21, 2014 | 10:00 PM
greenyone's Avatar
Car: 91 G92 Z28
Axle/Gears: 342
Yeah, and maybe new cam bearings since you don't have the cam that rode on those bearings. I'll think about that. I'm just looking to do a pretty basic stock build to replace the worn out 305 in my car. I was hoping to just find a complete short block that I could freshen up.
Old Jul 22, 2014 | 06:52 AM
greenyone's Avatar
Car: 91 G92 Z28
Axle/Gears: 342
Only other question I can think of is...was the block every decked?
Old Jul 22, 2014 | 06:56 AM
jonarotz's Avatar
Car: 91 Z28
That's a good question...yes it was when all the other work was done. The machinist took off just enough to square it up. I can't remember how much but it was very little because I didn't want him to go crazy. All the machine work was done by Victory Racing Engines here in Cleveland.
Old Jul 27, 2014 | 10:28 PM
david frederick's Avatar
87' corvette 58k roller short block 600. Dave Berea Ohio
Old Aug 6, 2014 | 11:27 AM
Joe Reece's Avatar
Car: 4-1991 1LE Formulas
Engine: LB9
Axle/Gears: 342
Have 1992 L98 from a Trans AM Long block.
$400.00 Thirdgenunlimted. 3.5 hours from Pittsburgh.
Old Aug 6, 2014 | 11:47 AM
greenyone's Avatar
Car: 91 G92 Z28
Axle/Gears: 342
Thanks guys. I have an engine/block at the machine shop right now getting checked out. If it turns out to be junk I'll hit you guys up.
Jake_92RS
Jan 28, 2020 10:37 PM
Infested
May 22, 2018 11:56 PM
theshackle
Mar 5, 2017 06:37 PM
camaro71633
Sep 1, 2015 10:24 AM
BBSDesigns
Aug 11, 2015 07:39 PM
