[TX] WTB gas tank from a 85-92 camaro-firebird
Car: 09 civic si, 87 Firebird formula
Engine: I-vtec DOHC, 305 carb
the car i bought had a rusted out gas tank and had to toss it, i am at fort bliss texas and the gas tank is all that is holding me back from starting the car, My car is an 87 firebird formula with the 305 v8 and a t5 Tranny
Car: 88GTA
Engine: 5.7TPI
Re: WTB gas tank from a 85-92 camaro-firebird
Saphmeresis...you didn't toss the fuel pump and sender did you? Or did you buy new.
From what I heard, your best bet would be to go to the salvage yard and pick up a original one and clean it all up in and out.
The aftermarket ones don't seem to fit that well.
Car: 91 ws6
Engine: Carb'd 334 stroker
I have one without the su, has some rust inside but nothing that can't be cleaned out. I drove the car around for a while as is, no problems. No punctures or other damage.
mostly it's on the front bottom part of the tank, looks like it sat with like a gallon in at one point in its life
can you wait till after my next paycheck, i would say the first of dec but i go to the field that day, and could you ship it to a P.O. box, gotta love the military life.
Car: 91 ws6
To be clear, the rust on mine is internal, not external
I can Deal with that rust as long as it was not as bad as the one i had
Car: 91 ws6
If its bad enough that you didnt even want to turn it over then..yikes.. mine needed its filter changed out a bit more frequent than usual, but that's about it. Mostly due to just needing cleaned out, which I never dropped the tank/was lazy. I'll try and get some pics this weekend for ya
Car: 1985 Trans Am T-Top
Transmission: T-5 5 Speed
Axle/Gears: 3.42 posi 1LE 10 bolt
Wait till you find out how much it will cost you to ship that tank!
Remember, the filler pipe is attached. It takes a big box to fit.
Best way to get a tank is a parts car or someone parting third gens. You may find that some of the better JY are aware of the value of an old rank and didn't puncture it.
Dont be afraid of some surface rust or small leaks. The tanks can be reconditioned and will be waaaaaaaay better than the aftermarket replacement.
Saxondale
Exterior Parts Wanted
Sep 7, 2015 06:11 PM
Saxondale
Exterior Parts for Sale
Sep 7, 2015 11:40 AM
