Electric speed sensor needed
Car: 86 Trans Am WS6
Engine: 383 stroker
Hey, I need a working Electric speed sensor for an 86 trans am 305tpi with a 700r4 transmission.
Car: 91 ws6
Engine: Carb'd 334 stroker
Engine: 383 stroker
Car: 91 ws6
Engine: 383 stroker
Car: 91 ws6
Car: 91 Camaro RS
Engine: 305 TPI conversion.
Re: Electric speed sensor needed
there are two different versions of the speed sensor. 53mm and 22mm. you need to determine which one you need for your application. a 53mm can be picked up at parts stores or ebay for around 25 bucks. the 22mm are no longer made and very hard to find. ive seen them go for over 100.
Engine: 383 stroker
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
This is the type of electric speedo sensor you need for an 87 Firebird auto:
There are more than 1 version of THIS sensor. They are made to fit a specific range of speedo DRIVEN gears. What is your gear ratio ??
Engine: 383 stroker
I talked to transmissioncenter.net on the phone a couple days ago and got one ordered
Cool - good to hear you got it figured out. FYI: remember that the electric speedo gears and mechanical speedo gears are NOT compatible.
IIRC you'll need a Brown 39 tooth Driven gear for electric VSS with 2.73/2.77. ( double check that tooth count !! ) BE SURE the sending unit will accept the correct DRIVEN GEAR before you buy it !
Example: This vss will NOT work for 39 tooth gear !
Engine: 383 stroker
