Throttle cable clip
Car: 1989 IROC
Engine: 5.7 TPI
Axle/Gears: 2.77 Posi
Throttle cable clip
Looking for the cable retaining clip that mounts on the drivers side intake runner between the 2 front and 2 rear tubes.
ETA: This is for an '89 IROC L98. Looking for the 3-wire loom, not the 4-wire loom.
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Throttle cable clip
Car: 1989 IROC
Engine: 5.7 TPI
Unless your throttle cable runs naturally, very close to the stud in question, the tension of the throttle cable will just pop the keeper open anyway. That's just one part of the reason they're often gone. FWIW. It stings a bit when you search and finally find, snap it into place, then a few weeks later you notice the cable has popped out, and then keeps popping out. So then you try another one, and it happens again.
Car: 1989 IROC
Engine: 5.7 TPI
Mine was broken when I bought the car, so I will try a replacement if I can find one. If that doesn't work I guess I'll just live with it as is or find another solution.
zacharyhorn
Carburetors
Apr 12, 2012 08:38 AM
TekViper
Feb 10, 2005 10:55 PM
