ISO Firehawk ZF s6-40 6 speed crossmember and trans tunnel hump
Old Sep 14, 2022 | 03:33 PM
firebirddude142's Avatar
Car: 1992 Trans Am GTA
Engine: L98 5.7L 350
ISO Firehawk ZF s6-40 6 speed crossmember and trans tunnel hump. Also would be interested in a complete swap but mainly the crossmember since that’s the only part I cannot fabricate and look original.
I am building a true clone and I am down to the last couple unicorn parts. Any help would be greatly appreciated.
let me know what you have. i also have lots of nos and rare hard to find parts to trade and make a deal.
Please text or pm me my number is 612-860-2513
Old Sep 16, 2022 | 02:17 PM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
Re: ISO Firehawk ZF s6-40 6 speed crossmember and trans tunnel hump
I bet you could take a 200R4 crossmember or two and with some careful cutting and welding to merge the shapes you could make it look exactly like that. no doubt it will take some real work with the welder and grinder but it has the general look
Old Sep 16, 2022 | 04:40 PM
yeah a tta one is similar and it could possibly be done but I rather find one I know they are out there.
Old Oct 10, 2022 | 09:37 PM
Still searching!!! Need them to complete my zf swap for my firehawk clone. Last parts needed. Already have t ram, dual intake(nos), wheels totl(nos), tri ys complete with dual cats, Recaro seats, aluminum hood, correct battery cable, correct spark plug wires, and the correct BREMBOS!
Old Nov 30, 2025 | 05:19 AM
3R1$C's Avatar
Car: 1985 Camaro
Question: what modifications, i.e. what welding and cutting is required if one was to use the C4 bellhousing?
Old Nov 30, 2025 | 08:22 AM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
A lot due to the clutch type and hydraulics setups
Old Nov 30, 2025 | 02:07 PM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
Stick to an aluminum version instead of mag.
The Quicktime for LS is steel.
Old Jan 8, 2026 | 08:40 AM
I actually already have the correct bellhousing now I just really need the crossmember
Old Jan 8, 2026 | 07:11 PM
jmd's Avatar
jmd
Don't let "correct" stop you now! Steel is too easy to work with to not put something together as a cross member.
Iroc'nthe87
Jul 9, 2016 07:02 PM
1986chevycamaro
Oct 14, 2013 07:05 PM
MrBrooks
Jul 1, 2007 11:57 AM
